March 16Mar 16 Hi everyone,I'm running into a critical issue with my Unraid server. The array starts up fine, but after running normally for a while, the user share system seems to crash.When this happens, the "Shares" tab in the WebGUI goes completely blank, and all of my network shares become inaccessible.If I try to check the directory via the terminal, I get the following FUSE error:root@Tower:/mnt# ls ls: cannot access 'user': Transport endpoint is not connectedSymptoms:The array remains started, but user shares drop out unexpectedly after some uptime.Terminal confirms /mnt/user is inaccessible with the "Transport endpoint is not connected" error.The "Shares" page in the WebGUI is completely empty. tower-diagnostics-20260316-2339.zip
March 16Mar 16 Community Expert Your have corruption on disk1, but you also have btrfs csum errors on /dev/loop2 (docker.img)btrfs csum errors are usually bad RAM. Very important you take care of that before trying to repair disk1.memtest is on the boot menu
March 16Mar 16 Community Expert 3 hours ago, harrymay said:"Transport endpoint is not connected" error.From what I recall this mean FUSE has crashed. Likely caused by whatever else is going bad.
March 16Mar 16 Community Expert I would consider a 24 hour minimum memory test which you can access from the unraid boot menu screen (blue square screen)
March 16Mar 16 Community Expert You must not attempt to run any computer unless memory is working perfectly. Everything goes through RAM. The OS and other executable code, your DATA. EVERYTHING! The CPU can't do anything with anything until it is loaded into RAM.
March 17Mar 17 Author Thank you so much for pointing me in the right direction I ran Memtest86+ from the boot menu as suggested. It didn't even need 24 hours—within just 3 minutes, the screen lit up with red errors.
March 17Mar 17 Community Expert 1 hour ago, harrymay said:Thank you so much for pointing me in the right directionI ran Memtest86+ from the boot menu as suggested. It didn't even need 24 hours—within just 3 minutes, the screen lit up with red errors.Yup that's no good, time to replace the RAM. you can test each stick individually if you really want to only replace the bad DIMMs but that's your call.
March 18Mar 18 Author I went ahead and let Memtest86+ run for a full 24 hours with both sticks installed just to see the extent of the damage, and it threw over 1.2 million errors After that, I tested the sticks individually to isolate the issue. It turns out both sticks have physically failed and threw massive errors when tested alone
March 18Mar 18 Community Expert 1 hour ago, harrymay said:see the extent of the damageEven one error is too manyOn 3/16/2026 at 4:23 PM, trurl said:You must not attempt to run any computer unless memory is working perfectly.
March 25Mar 25 Author The new 32GB RAM kit arrived and is installed.I ran Memtest86+ and it successfully completed a full pass with absolutely zero errors. Seeing that big green "PASS" was a huge relief (screenshot attached).Now that the hardware foundation is finally stable and trustworthy, I have booted up Unraid and grabbed a fresh diagnostics file (attached) before attempting any repairs. tower-diagnostics-20260325-2144.zip
March 25Mar 25 Community Expert 20 minutes ago, harrymay said:Memtest86+ and it successfully completed a full passOn 3/16/2026 at 3:53 PM, MowMdown said:24 hour minimum memory testThen...All 3 disks are mounted, disk3 is empty which I assume is expected.On 3/16/2026 at 12:27 PM, trurl said:corruption on disk1Might be a good idea to check filesystem on disk1 anyway.On 3/16/2026 at 12:27 PM, trurl said:btrfs csum errors on /dev/loop2 (docker.img)docker.img still showing the corruption it already had. Delete, recreate, reinstall Previous Apps.https://docs.unraid.net/unraid-os/troubleshooting/common-issues/docker-troubleshooting/Might also be a good idea to do a parity check.Do you intend to have cache or other pool outside the parity array? It can have some benefits with docker even if you don't use it for caching.
