Network speed to unraid box stuck at 1.1 MB/sec or less [SOLVED]
My issue is fixed.  I removed the Intel nic that wasn't connected and now it's running back at normal speeds and syslog shows
Jul  6 17:32:50 NAS2 kernel: eth0: Identified chip type is 'RTL8168C/8111C'. (Network)
instead of the Intel® PRO/1000 Network Connection.
How and why it was using Intel drivers when the on-board was connected I won't know but who cares as long as it's back to normal.  I appreciate your help.
Sorry everyone for the delayed reply.  My new NIC arrived two days ago, but I just got around to installing it today.  I can happily report that this has solved my issue.  I just did some test transfers, and everything is working great!  :)
Good to hear. Did you disable your onboard LAN in the BIOS? I would recommend doing this if you haven't; it can help prevent conflicts and minimizes resource usage (though the performance gain is likely negligible).
Actually no I forgot to disable the onboard LAN, but I agree I do need to do that.  Thanks for the reminder.
