Network macvlan or ipvlan? Speed issue??
Hello good people:)
I have a problem getting the right speed in some of my docker containers.. I' ve tried to check almost everything, and now i have found that my docker network is running macvlan. I have seen somewhere that the best method is to change it to ipvlan. So my question is, is there a benefit for changeing it to ipvlan?? And if i change it, could there be any problems doing that?? Maybe some docker errors??
Hope you can help)
Thank you and regards
It shouldn’t affect anything anymore, long time ago there was a bug with Macvlan but that was fixed on unraid 6.12
Ipvlan is no longer a problem and can be used since Unraid 6.12.11.
Hello
I tried to change the network to ipvlan and that didnt work.. anyone who has an idea how to speedup the docker??
Thank you
