August 18, 201214 yr I have 4gb of RAM in my server but when I click on the INFO link of SimplyFeatures it reports only 512k. But, if I go to STATS/unRAID stats I slows a light less then 4gb. Is there somewhere else I can look to see the amount of RAM being used? Perhaps at the console? Thanks.
August 18, 201214 yr From telnet you can use "free -m" Here is some good info to know about how Linux considers what memory is free & what is used: http://www.linuxatemyram.com/
August 18, 201214 yr Author From telnet you can use "free -m" Here is some good info to know about how Linux considers what memory is free & what is used: http://www.linuxatemyram.com/ Thanks for this. What's weird is that it reports total RAM of 3549 which is less then 3.5gb. I'm not sure where I'm loosing about 1/2gb. Next time I powerdown the server I'm going to rerun the memory test. Cheers, Richard
August 18, 201214 yr Does your motherboard have onboard video? It might be assigned 512MB in bios. Or you might have a bad memory stick. I'd poke around in the CMOS settings and see what information you can get from there.
August 18, 201214 yr Author Does your motherboard have onboard video? It might be assigned 512MB in bios. Or you might have a bad memory stick. I'd poke around in the CMOS settings and see what information you can get from there. could be the video but I thought I had it set lower then that. I'll need to double check. Since I'm running headless I don't really need any RAM going to video.
August 18, 201214 yr could be the video but I thought I had it set lower then that. I'll need to double check. Since I'm running headless I don't really need any RAM going to video. I think the console still uses video ram, but if I remember correctly 256K is plenty to run the console. I remember when a 1MB video card was an upgrade, so that windows would look pretty. You probably don't have the option of lower than 8MB or so for shared video on a modern motherboard.
