August 9, 201313 yr So I started experiencing a problem (at least I think it is) with an Hitachi hard drive. unRAID has been running flawlessly for several months until this, no hardware changes. I noticed the problem while watching a HD movie while attempting to seek ahead, XBMC would stall for a couple of minutes and then return. Each subsuquent seek ahead for this particular movie was taking that long a time. Seek aheads are usually quick, so something's up. I traced down the movie to a particular disk and walked to the server and noticed the LED on my supermicro box for that disk was blinking ferociously, though a little dimmer than normal disk activity. And it would do this for each time I seeked ahead. Thoughts? EDIT: in the process of running a reiserfsck on the disk: reiserfsck --check started at Fri Aug 9 10:30:11 2013 ########### Replaying journal: Done. Reiserfs journal '/dev/sde1' in blocks [18..8211]: 0 transactions replayed Checking internal tree.. finished Comparing bitmaps..finished Checking Semantic tree: finished No corruptions found There are on the filesystem: Leaves 418812 Internal nodes 2610 Directories 7470 Other files 58265 Data block pointers 412762276 (0 of them are zero) Safe links 0 ########### reiserfsck fin smart.txt
