asus p5b-vmd0 help
I have a asus p5b-vmd0 motherboard and I am out of sata ports. I am using 2 pci monoprice 4 port sata cards
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10407&cs_id=1040702&p_id=2667&seq=1&format=2
. Now the question is can I use both the  PCI-E x16  and the PCI-E x4 slots
and install 2 of these http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10407&cs_id=1040702&p_id=2530&seq=1&format=2
This would allow an additional 4 ports?
Would this be faster than using the pci bus ??
If you have a P5B VM DO, then you have 7 on board SATA ports and 1 eSATA port.  With an e-Sata to Sata cable you can have 8 internal sata ports.
This MB has 2 PCI-e slots - 1 4x and 1 16x.  You CAN use both of these slots and still have the onboard video function.
I would recommend 2 Adaptec 1430SA cards.  Each has 4 full speed SATA ports.  With the motherboard (8) + 2 of the these (2x4=8) you would have 16 full speed sata ports.
PCI-based boards are okay, but will get slow on parity checks if you go over 2 or 3 PCI drives.
Yeah the cards are expensive in Canada that is why I was looking at the throw away monoprice cards with the sil3132 chipset. If they will be fine for streaming my movies I will buy them. The pci versions work fine. But maybe that is why my parity is so slow. I have it hooked up to the last port of my second  4 port pci card. Maybe I should by the pci-e versions and hook up the parity drive to that.
The trade offs between PCI vs PCI-e are well documented in the forums.  Check out the "Best of the Forums" link in my sig.  There is a PCI vs PCI-e link that I wrote a while back that explains it pretty well and gives some benchmarks.
Bottom line, though - 1-2 drives on the PCI bus is fine.  3-5 will slow down parity checks but still pretty reasonable.  >5 will really bog down parity checks.  But if you can live with the lengthy parity checks (we're only talking about a day a month that you are running them), PCI is just as fast as PCI-e for situations where the bus is not saturated.  And saturating the bus is pretty darn hard to do with normal media use.
Have you used the e-SATA port on the back of the motherboard?  A $6 cable and you get another high speed port.  I'd definitely do that first!
