Fan Speed Control Trouble on Asrock E3C226D2I
For my EP2C602 the commands are slightly different. On this board, command
0x3a 0x01
works different:
ipmitool raw 0x3a 0x01 CPU_1_OVERRIDE CPU_1 REAR_1 FRONT_1 FRONT_2 UNKNOWN
So, only five fans can be set up and value
0x00
is just minimal speed, not automatic. Automatic speed can only be enabled for
CPU_1
by setting
CPU_1_OVERRIDE
to
0
(in which case the
CPU_1
value is ignored). So for 30% speed on all fans and
CPU_1
auto speed:
ipmitool raw 0x3a 0x01 0 30 30 30 30 30
CPU_2
can be controlled in the same way through another command,
0x3a 0x11
, which also controls two additional fans:
ipmitool raw 0x3a 0x11 CPU_2_OVERRIDE CPU_2 UNKNOWN UNKNOWN
ipmitool raw 0x3a 0x11 0 30 30 30
To get the current status of all fans, which also includes the current RPM of the CPU fans in auto mode:
ipmitool raw 0x3a 0x02
ipmitool raw 0x3a 0x12
0x3a 0x01
works different:
0x00
CPU_1
by setting
CPU_1_OVERRIDE
to
0
(in which case the
CPU_1
CPU_1
auto speed:
CPU_2
0x3a 0x11
That's some good info. Where'd you get it from? The current status command works for my board, which could be useful. Did you try the ipmi plugin? Looks like case fans could be controlled as it's currently written.
