Living Legend Posted April 29, 2015 Share Posted April 29, 2015 I'm having trouble setting up the VM network. I'm currently running mythbuntu as the OS. If set to DHCP, I can connect to the outside world. But apparently, with KVM (this didn't happen with XEN), some sort of configuration is different so that the VM is not recognized on the local network. The VM is also not able to recognize devices on the network. Hence, my problem. I'm trying to get mythTV to recognize my TV tuners, but it's not able to find them. I can ping the IP, but that's it. I can also access the outside world through a browser, but that doesn't help. I changed to a static IP, but this didn't work. I tried to set up a bridged connection, but I'm struggling with that now. Under network settings, the bridge name is set to br0. When I view the config file for the bridge: <interface type='bridge'> <mac address='52:54:00:bc:8a:49'/> <source bridge='virbr0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/> </interface> I don't know if these need to match, but they don't and I can't edit. The bridge connection inside the mythbuntu OS is called br0. My current VM network static config does not work. This is what my /etc/hosts/interfaces file looks auto lo iface lo inet loopback auto eth0 iface eht0 inet manual auto br0 iface br0 inet static address 192.168.1.111 network 192.168.1.0 netmask 255.255.255.0 broadcast 192.168.0.255 gateway 192.168.0.1 bridge_ports eth0 bridge_stp off brdige_fd 0 bridge_maxwait 0 When I view ifconfig from the VM terminal it lists out everything like it should be working. Any idea where I'm going wrong here? I've done tons of googling with my free time today, but to no avail. Link to comment
dmacias Posted April 29, 2015 Share Posted April 29, 2015 I'm having trouble setting up the VM network. I'm currently running mythbuntu as the OS. If set to DHCP, I can connect to the outside world. But apparently, with KVM (this didn't happen with XEN), some sort of configuration is different so that the VM is not recognized on the local network. The VM is also not able to recognize devices on the network. Hence, my problem. I'm trying to get mythTV to recognize my TV tuners, but it's not able to find them. I can ping the IP, but that's it. I can also access the outside world through a browser, but that doesn't help. I changed to a static IP, but this didn't work. I tried to set up a bridged connection, but I'm struggling with that now. Under network settings, the bridge name is set to br0. When I view the config file for the bridge: <interface type='bridge'> <mac address='52:54:00:bc:8a:49'/> <source bridge='virbr0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/> </interface> I don't know if these need to match, but they don't and I can't edit. The bridge connection inside the mythbuntu OS is called br0. My current VM network static config does not work. This is what my /etc/hosts/interfaces file looks auto lo iface lo inet loopback auto eth0 iface eht0 inet manual auto br0 iface br0 inet static address 192.168.1.111 network 192.168.1.0 netmask 255.255.255.0 broadcast 192.168.0.255 gateway 192.168.0.1 bridge_ports eth0 bridge_stp off brdige_fd 0 bridge_maxwait 0 When I view ifconfig from the VM terminal it lists out everything like it should be working. Any idea where I'm going wrong here? I've done tons of googling with my free time today, but to no avail. Change the source bridge virbr0 to br0 in your xml. Link to comment
Living Legend Posted April 29, 2015 Author Share Posted April 29, 2015 When I edit the XML file and hit done, it doesn't seem to save the change. Link to comment
Living Legend Posted April 29, 2015 Author Share Posted April 29, 2015 When I edit the XML file and hit done, it doesn't seem to save the change. I shutdown the VM and was able to edit. I'll see if I can get it up and running now. Link to comment
Living Legend Posted April 29, 2015 Author Share Posted April 29, 2015 Worked like a charm now that I figured how to edit. Link to comment
