January 2, 200719 yr I am stuck with this on my server: I have telnet'd in and rebooted...I have even pulled the plug and did a hard restart. The lights on the machine seem to be all working. I think it is doing a parity check. I have cleared the cache and temp files from my computer (thinking it could be an issue of seeing an old webpage) but still nothing. Even tried other computers on the network...same thing. When I try to browse to the server, it only shows the flash drive, no other drives....I hope it is not clearing all drives.......that would suck! There is no use in stopping it now, because if it started clearing them......it would still be ruined, but I would like to figure this out. The whole situation started with it showing a bad drive 11 which was a segate 500GB drive. Well I replaced it with an older 200 GB drive to see if that helped, but showed the whole thing with errors again. Any help would be great.
January 2, 200719 yr Well, based on the screen shot it's stuck mounting a drive. The only way to diagnose the issue is to get a copy of the syslog file. If you post here I can take a look at it, but I would suggest sending it to Tom via mail as well. It is the holidays so I don't know how quickly he will be able to get to it.
January 2, 200719 yr Just read your note again. If you had a bad drive replaced it and still have errors that could be an indication that it wasn't the drive at all and could be the cable, power, or controller, etc. I had a flaky/loose SATA PORT on one of my non-unRAID systems the other day so even that can be an issue sometimes.
January 2, 200719 yr I don't think you can replace a drive with another drive smaller than the one you wish to replace. Your 500 GB cannot be replaced by a 200 GB, maybe that is what is causing Unraid to get stuck.
January 2, 200719 yr I don't think you can replace a drive with another drive smaller than the one you wish to replace. Your 500 GB cannot be replaced by a 200 GB, maybe that is what is causing Unraid to get stuck. Gnollo, I thought you could if there was no data on it or at least less data than the total of the new drive. Tom would probably be able to answer that though. Looking at the screen shot the guy provided he has a lot of free space so I imagine if there was data on the bad drive he moved it to another drive before replacing.
January 2, 200719 yr Author Here you go....very little of the log as it kept going for over 5 min. Hope this little bit helps. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75784, count=120 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75784 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75784/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75792, count=112 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75792 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75792/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75800, count=104 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75800 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75800/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75808, count=96 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75808 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75808/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75816, count=88 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75816 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75816/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75824, count=80 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75824 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75824/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75832, count=72 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75832 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75832/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75840, count=64 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75840 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75840/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75848, count=56 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75848 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75848/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75856, count=48 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75856 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75856/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75864, count=40 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75864 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75864/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75872, count=32 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75872 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75872/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75880, count=24 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75880 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75880/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75888, count=16 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75888 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75888/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75896, count=8 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75896 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75896/11, count: 6, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75904, count=128 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75904 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75904/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75912, count=120 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75912 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75912/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75920, count=112 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75920 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75920/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75928, count=104 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75928 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75928/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75936, count=96 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75936 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75936/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75944, count=88 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75944 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75944/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75952, count=80 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75952 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75952/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75960, count=72 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75960 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75960/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75968, count=64 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75968 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75968/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75976, count=56 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75976 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75976/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75984, count=48 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75984 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75984/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=75992, count=40 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 75992 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 75992/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76000, count=32 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76000 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76000/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76008, count=24 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76008 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76008/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76016, count=16 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76016 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76016/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76024, count=8 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76024 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76024/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76032, count=128 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76032 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76032/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76040, count=120 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76040 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76040/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76048, count=112 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76048 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76048/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76056, count=104 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76056 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76056/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76064, count=96 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76064 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76064/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76072, count=88 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76072 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76072/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76080, count=80 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76080 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76080/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76088, count=72 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76088 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76088/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76096, count=64 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76096 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76096/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76104, count=56 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76104 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76104/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76112, count=48 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76112 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76112/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76120, count=40 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76120 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76120/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76128, count=32 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76128 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76128/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76136, count=24 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76136 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76136/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76144, count=16 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76144 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76144/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76152, count=8 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76152 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76152/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever kernel: hdh1: bad access: block=76160, count=128 Jan 1 15:08:17 ThanosNASSever kernel: end_request: I/O error, dev 22:41 (hdh), sector 76160 Jan 1 15:08:17 ThanosNASSever kernel: md11: read error! Jan 1 15:08:17 ThanosNASSever kernel: end_read_request 76160/11, count: 7, upto date 0. Jan 1 15:08:17 ThanosNASSever root@ThanosNASSever:~#
January 2, 200719 yr Well, That pretty much says it all. There is a read error on the drive that is named hdh. IF this is during the mounting process that is bad cause it sounds like unraid cannot read the FS at all. I would recommend getting the entire syslog and mailing it to Tom. [email protected]
January 3, 200719 yr The whole situation started with it showing a bad drive 11 which was a segate 500GB drive. Well I replaced it with an older 200 GB drive to see if that helped, but showed the whole thing with errors again. Initially, how did you know the original disk11 was 'bad'? From the screenshot, looks like it's doing a parity-sync (building parity). If this is the case, I suggest you shut it down (just power off if you have to), remove disk11, power up, 'restore' configuration, and the Start. Data disks1..10 should mount normally, and a parity sync should start & you should see the disks appear on your network. Get your system back to a known good state without disk11 plugged in, and then we can embark on further troubleshooting related to disk11.
January 3, 200719 yr Author Ok....doing parity sync without issues. No drive 11 installed. Luckly I didn't send the Seagate 500GB drive back yet! New thoughts, Tom?
January 3, 200719 yr Author Initially, how did you know the original disk11 was 'bad'? It showed almost all errors, then when I rebooted the server, it showed it unformatted, then it had the wrong drive serial and type. Then would not format correctly. All weird things like that.
January 3, 200719 yr Initially, how did you know the original disk11 was 'bad'? It showed almost all errors, then when I rebooted the server, it showed it unformatted, then it had the wrong drive serial and type. Then would not format correctly. All weird things like that. Did it work correctly at one time? If you had a 12-drive system, with parity generated, then if disk11 started to "die" I would expect that the system would have disabled it at some point (the LED icon next to the disk turning red).
January 3, 200719 yr Author To be honest, there was nothing on it, and with the holidays I was not transferring anything, so I don't know if it was STARTING to die or not. I just noticed that one day it showed unformatted.
