jimbohead Posted January 5, 2016 Share Posted January 5, 2016 Hi All, I have read through several threads on this here, but need a little more help. I have an existing 2.5 SATA HDD as my cache drive and just want to clone it to a brand new SSD. So far, I have.. -turned off docker and disabled autostart on all plugins -physically removed the cache drive and replaced it with the new SSD -formatted the new SSD as XFS (starting array, formatting then stopping array) -re-connected old cache drive via USB-SATA adapter -mounted both the old cache drive and new SSD using unassigned devices plugin here's where I'm stuck.. -I tried running Midnight Commander (directly from console) as many here have recommended, but cant for the life of me figure out how to do a simple cloning of the old drive to the new. Any assistance would be greatly appreciated! Thanks so much in advance! Link to comment
trurl Posted January 5, 2016 Share Posted January 5, 2016 The current (new) cache drive is at /mnt/cache. The old cache drive is at /mnt/disks/whatever unassigned devices called it. Copy from the old to the new. Link to comment
jimbohead Posted January 5, 2016 Author Share Posted January 5, 2016 Thanks for the quick reply, trurl! Unfortunately, this GUI isn't as straightforward as I thought. the /mnt folder doesn't have a cache folder (only shows /disks with the /Samsung_~M-part1 and /_part1 (both look to be empty)) Is there no easy command to just clone drive a to drive b? Link to comment
trurl Posted January 5, 2016 Share Posted January 5, 2016 Is the array started with the new cache already assigned? Link to comment
jimbohead Posted January 5, 2016 Author Share Posted January 5, 2016 Negative. Should I start the array with the new drive assigned? Link to comment
jimbohead Posted January 5, 2016 Author Share Posted January 5, 2016 If I start the array and run MC, I see the old cache drive but it is unreadable. (File format I should mention is EXT4 for the old cache drive) Link to comment
trurl Posted January 5, 2016 Share Posted January 5, 2016 If I start the array and run MC, I see the old cache drive but it is unreadable. (File format I should mention is EXT4 for the old cache drive) EXT4 has never been a supported format for cache drives. unRAID only supports ReiserFS, XFS, btrfs for cache or any array drive. I'm not sure whether unassigned devices supports that or not. Was it actually working as a cache drive for you? Link to comment
jimbohead Posted January 5, 2016 Author Share Posted January 5, 2016 Yep it was working just fine. I think I finally figured it out. Once I started the array, the old cache drive had a part1 folder that contained all the files in the root. Transfer is in progress now (probably should have just installed both drives internally vs mounting the original one externally with the adapter). Will report back in about an hour (the ETA it shows for 22GB file transfer). Thanks again, trurl! Link to comment
jimbohead Posted January 5, 2016 Author Share Posted January 5, 2016 Wanted to close the loop on this, copy finished using MC and all seems to be well! Thanks so much trurl! Link to comment
