mrmarkfr Posted January 10, 2016 Share Posted January 10, 2016 I have an issue where my UPS is not reporting the load usage, so it can't determine the run time. All the rest of the UPS details are showing up, except for load. I thought it might have to do with my unmenu not working, but I fixed that today, and same issue. The only anomaly I can see is that for all my other packages(mail, clean powerdown, etc, they show as currently installed, will automatically be reinstalled upon re-boot. The package for the APCUPSD shows as installed, not downloaded. Here's my ups info, anyone have any ideas? APC : 001,034,0851 DATE : 2016-01-10 16:31:22 -0500 HOSTNAME : unraid1 VERSION : 3.14.13 (02 February 2015) slackware UPSNAME : unraid1 CABLE : USB Cable DRIVER : USB UPS Driver UPSMODE : Stand Alone STARTTIME: 2016-01-10 15:29:52 -0500 MODEL : Back-UPS ES 550G STATUS : ONLINE LINEV : 121.0 Volts LOADPCT : 0.0 Percent BCHARGE : 100.0 Percent TIMELEFT : 450.0 Minutes MBATTCHG : 30 Percent MINTIMEL : 30 Minutes MAXTIME : 1200 Seconds SENSE : Medium LOTRANS : 92.0 Volts HITRANS : 139.0 Volts ALARMDEL : 30 Seconds BATTV : 13.5 Volts LASTXFER : Unacceptable line voltage changes NUMXFERS : 0 TONBATT : 0 Seconds CUMONBATT: 0 Seconds XOFFBATT : N/A STATFLAG : 0x05000008 SERIALNO : 4B1511P32081 BATTDATE : 2015-03-12 NOMINV : 120 Volts NOMBATTV : 12.0 Volts FIRMWARE : 904.W1 .D USB FW:W1 END APC : 2016-01-10 16:31:44 -0500 Link to comment
cfloener Posted January 10, 2016 Share Posted January 10, 2016 Might fall under the same problem I am having. http://lime-technology.com/forum/index.php?topic=45088.0 Link to comment
CHBMB Posted January 10, 2016 Share Posted January 10, 2016 It is the same problem by the looks of it. Might be better if the OP posted there so dlandon has it all in one thread. mrmarkfr could you also collect diagnostics.zip and post it on the thread cfloener has linked to.. Link to comment
mrmarkfr Posted January 10, 2016 Author Share Posted January 10, 2016 Posted diag.zip in the other post, this thread can be deleted Link to comment
