IOMMU Container Problem
what does this mean and how to resolve it ?
in the Bios IOMMU is enabled and all the cpu virtual thing is enabled as well
ErrorWarningSystemArrayLogin
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 1]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 2]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 3]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 4]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 5]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 6]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 7]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 8]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 9]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 12]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 13]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 14]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 15]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 16]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 17]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 23]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 24]
warning: host doesn't support requested feature: CPUID.80000001H:EDX [bit 0]
2016-12-03T13:36:23.365125Z qemu-system-x86_64: -device vfio-pci,host=08:05.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to set iommu for container: Operation not permitted
2016-12-03T13:36:23.365142Z qemu-system-x86_64: -device vfio-pci,host=08:05.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to setup container for group 14
2016-12-03T13:36:23.365149Z qemu-system-x86_64: -device vfio-pci,host=08:05.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to get group 14
2016-12-03T13:36:23.365158Z qemu-system-x86_64: -device vfio-pci,host=08:05.0,id=hostdev0,bus=pci.0,addr=0x5: Device initialization failed
2016-12-03 13:36:23.433+0000: shutting down
Managed to get the cpu part working
but im getting this error when trying to pass-through GPU and Sound card
this is the gpu
2016-12-03T22:08:37.734825Z qemu-system-x86_64: -device vfio-pci,host=01:00.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to set iommu for container: Operation not permitted
2016-12-03T22:08:37.734847Z qemu-system-x86_64: -device vfio-pci,host=01:00.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to setup container for group 16
2016-12-03T22:08:37.734854Z qemu-system-x86_64: -device vfio-pci,host=01:00.0,id=hostdev0,bus=pci.0,addr=0x5: vfio: failed to get group 16
2016-12-03T22:08:37.734863Z qemu-system-x86_64: -device vfio-pci,host=01:00.0,id=hostdev0,bus=pci.0,addr=0x5: Device initialization failed
2016-12-03 22:08:37.781+0000: shutting down
