June 24, 20179 yr Hello! As a foreword I am very new to unRAID and know very little about how to actually work it. So right now I have unRAID 6.3.5 and have installed the owncloud docker. I have it all up and working and can remotely access it from outside my network through a domain that is setup to forward to my IP. The big problem is that it is not a secured connection from outside. I have a Netgear Nighthawk X9000 that I have openVPN setup on with DDNS (through NoIP) already watching itself, but I don't know where I would put in an SSL key or even how to get to its web GUI. Anyone have any ideas? I don't even know at what point do I add in that SSL anyway? Do i need to get a new key through my command prompt and put it in the config file before reinitializing open VPN on the router? Do I need to make a wordpress website as a docker that links to the owncloud docker and put SSL on it? Just feeling lost and a little overwhelmed so any advice or help is much appreciated.
June 24, 20179 yr 9 minutes ago, Kiyometa said: Just feeling lost and a little overwhelmed so any advice or help is much appreciated. Install this first Then install this and this by following this tutorial https://www.linuxserver.io/2017/05/10/installing-nextcloud-on-unraid-with-letsencrypt-reverse-proxy/ to get it all working together.
