is there a ultra-short rackmount backplane / case available or parts for DIY?
Hi folks,
I need to install my home unRAID into an ultra-short wall-mounted rack.
Outside rack depth is 395mm/~15.5in - inside available depth
for a chassis is approx 250mm/~9.8in..maybe one inch more.
I wonder whether there is a 3U chassis or SATA Backplane somewhere to
buy or to build (4 holding the drives) - or a 4U chassis to mount the MoBo
on top of the 3U drives setup - with that depth?
Alternatively an enclosure where one could mount some standard
(i.e. 5x3.5 in 3x5.25) backplanes?
TIA,
  fred
Depending on your space, you may be able to use something like this to give yourself some breathing room:
http://www.rackmountsolutions.net/Standoff_Rack_Extender.asp
We used these in two post racks so that the servers were more centered in the two-post racks.
Also, I've recently been shopping for chassis, and ran across this on Newegg:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811165211
It's the shortest depth I've seen that would still accommodate hot swap disks easily.
Thanks for your kind and fast response, DocBlock.
I am actually using a real cabinet...sorry for not being specific
enough, but English is not my native tongue.
So extending it is not an option, i am afraid.
...the cabinet is 12U and my first version will start with mounting an ICY-Dock
5-in-3-SATA Backplane onto a 250mm depth tray/shelf.
The ITX MoMo will go into a Supermicro 1U chassis
