skeil909 Posted January 14, 2018 Share Posted January 14, 2018 This is a clean 6.4.0 install that's only been running a few days. ALL drives are set to never spin down. Each drive is individually set to Never and the system settings are globally set to Never. Oddly enough something is still causing the shares to be unavailable for 10-30s every morning and several times throughout the day. I don't remember having this issue with 6.3.5. Am I missing something? MB - Asus Z9PE-D16 CPU- 2 x Xeon E5-2690 RAM- 64GB ECC NIC - 10GB MELLANOX CONNECTX-2 PCIe HDD - 2 x 3TB WD Red (1 parity, 1 data) HDD - 2 x 3TB Seagate (data) HDD - 2 x 500GB 850 EVO SSD's (cache pool) Current Plugins Community Applications Dynamix SSD Trim Dynamix System Buttons Dynamix System Information Dynamix System Statistics Dynamix System Temperature Fix Common Problems Nerd Tools Unassigned Devices Current Dockers binhex-delugevpn binhex-emby Link to comment
Squid Posted January 14, 2018 Share Posted January 14, 2018 10 minutes ago, skeil909 said: 10-30s every morning Is it the same time every morning? What does the log show? Link to comment
skeil909 Posted January 14, 2018 Author Share Posted January 14, 2018 8 minutes ago, Squid said: Is it the same time every morning? What does the log show? Nothing in the log and it's been every morning on the 1st use and then random times during the day after periods of non-use. Jan 14 03:40:11 unRipper root: move: file /mnt/cache/Downloads/Switch IE Proxy.msi Jan 14 03:40:11 unRipper shfs: set_nocow path: /mnt/cache/domains Jan 14 03:40:11 unRipper shfs: set_nocow path: /mnt/cache/system Jan 14 03:40:11 unRipper root: move: skip /mnt/disk1/system/docker/docker.img Jan 14 03:40:11 unRipper root: move_object: /mnt/disk1/system/docker: Directory not empty Jan 14 03:40:11 unRipper root: move: skip /mnt/disk1/system/libvirt/libvirt.img Jan 14 03:40:11 unRipper root: move_object: /mnt/disk1/system/libvirt: Directory not empty Jan 14 03:40:11 unRipper root: move_object: /mnt/disk1/system: Directory not empty Jan 14 03:40:11 unRipper root: mover: finished Jan 14 06:30:06 unRipper root: /etc/libvirt: 1022.5 MiB (1072177152 bytes) trimmed Jan 14 06:30:06 unRipper root: /var/lib/docker: 17.2 GiB (18458447872 bytes) trimmed Jan 14 06:30:06 unRipper root: /mnt/cache: 929.7 GiB (998198837248 bytes) trimmed Link to comment
Squid Posted January 14, 2018 Share Posted January 14, 2018 2 minutes ago, skeil909 said: Nothing in the log and it's been every morning on the 1st use and then random times during the day after periods of non-use. Try referencing all of your shares / server's on the client PCs based upon their IP address instead of the server's name. Probably down to Windows / SMB issues. Referencing via IP usually solves all. Or peruse the Windows issues with unRaid thread. Link to comment
skeil909 Posted January 14, 2018 Author Share Posted January 14, 2018 54 minutes ago, Squid said: Try referencing all of your shares / server's on the client PCs based upon their IP address instead of the server's name. Probably down to Windows / SMB issues. Referencing via IP usually solves all. Or peruse the Windows issues with unRaid thread. Using the IP seems to be working much better. Thanks. Link to comment
skeil909 Posted January 21, 2018 Author Share Posted January 21, 2018 Found the actual cause of my issues. SMB 1.0/CIFS Client was turned off. Windows 10 Turn Windows features on or off SMB 1.0/CIFS File Sharing Support Enable SMB 1.0/CIFS Client (Was turned off) unRAID now shows up and works fine. It also fixed a problem with Emby not playing media from the browser. Emby would return an error "no streams available". Link to comment
