jawolf Posted February 25, 2018 Share Posted February 25, 2018 I recently started converting my ReiserFS disks to XFS using the mirror procedures outlined here -->http://lime-technology.com/wiki/File_System_Conversion. After completing the first two disks (disk1 and disk2), I noticed that files on the converted disks do not show up in my user shares even though all disks are included in the shares. Files are present on the individual disks. On the Shares page in the gui, disk1 and disk2 show up in the User Shares section along with my other shares and there is no Disk Shares section. I'm assuming that this is related to the conversion because all of the other disks in the array appear fine. I've checked my Global Share Settings and each of the user share settings and they look correct. Is there something I missed in the conversion process or is there something else going on? Thanks! clark-diagnostics-20180225-1120.zip Link to comment
Squid Posted February 25, 2018 Share Posted February 25, 2018 You had an extraneous "/" at the end of one of the commands which resulted in the files being moved into a share called Disk1 and Disk2. Do all of the files exist within those shares? Link to comment
jawolf Posted February 25, 2018 Author Share Posted February 25, 2018 Yes, all of the files are on those shares. How do I remove the shares that I shouldn't have created and get the files back where I want them on the other shares? Link to comment
Squid Posted February 25, 2018 Share Posted February 25, 2018 Personally, I would do it either through the Krusader docker app, or over the network. Krusader (or alternatively mc at the command prompt) would be the fastest. IE: You're doing a Cut & paste from the Disk1 share to the Movies (eg) Share Link to comment
jawolf Posted February 25, 2018 Author Share Posted February 25, 2018 I used Krusader to move the files to the correct share. Now I just have to make sure I get the command right for rest of my drives. Thanks so much for the help! Link to comment
