dapice Posted March 1, 2018 Share Posted March 1, 2018 i am getting this error in the plugin fix common problems: Your server has detected hardware errors. You should install mcelog via the NerdPack plugin, post your diagnostics and ask for assistance on the unRaid forums. The output of mcelog (if installed) has been logged has been working well most of the time but every 2-4 days it becomes unresponsive and i need to reboot for it to work. i have downloaded mcelog and attached the log as i cannot figure out the issue. backup-diagnostics-20180228-1940.zip Link to comment
JorgeB Posted March 1, 2018 Share Posted March 1, 2018 Not sure what the hardware errors are about but since it's ryzen you need to disable C-states, search for ryzen here: Link to comment
