aflores3 Posted April 26, 2018 Share Posted April 26, 2018 So I had a drive go down. I replaced it as I've done in the past, and I can't get my parity to rebuild since it is running so incredibly slow. For full disclosure, I'm so over my head with this. My server has been running fine for a couple of years, but now that I'm having issues, I have no idea how to diagnose. I have seen the following in my logs Tower kernel: ata1.01: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen Info: Unraid Version: 6.4.0 M/B: Gigabyte Technology Co., Ltd. - GA-78LMT-S2P CPU: AMD FX™-8300 Eight-Core @ 3300 HVM: Disabled IOMMU: Disabled Cache: 128 kB, 2048 kB Memory: 8 GB (max. installable capacity 8 GB) Network: eth0: 1000 Mb/s, full duplex, mtu 1500 Kernel: Linux 4.14.13-unRAID x86_64 I'll be happy to run any other diagnostics and/or provide any other logs, I just don't know where to start, frankly. tower-diagnostics-20180426-1120.zip Link to comment
JorgeB Posted April 26, 2018 Share Posted April 26, 2018 Two of your onboard SATA ports (usually ports 5 and 6) and configured as IDE, enter board bios and change to SATA/AHCI then try rebuilding again. Link to comment
JorgeB Posted April 26, 2018 Share Posted April 26, 2018 P.S. disk7 was not mounting and it was formatted, I hope you knew what you're doing, i.e., all data on it was lost. Link to comment
aflores3 Posted April 26, 2018 Author Share Posted April 26, 2018 I'll change the boards bios as soon as i get home from work. Re: disk 7 ... I hate to shatter your hopes, but no, I did not know what I was doing and did, in fact, lose some data. On the plus side, it wasn't much, but still hurt. Thanks for your response. Link to comment
aflores3 Posted April 26, 2018 Author Share Posted April 26, 2018 6 hours ago, johnnie.black said: Two of your onboard SATA ports (usually ports 5 and 6) and configured as IDE, enter board bios and change to SATA/AHCI then try rebuilding again. This did the trick. I also moved my parity drive off of my pci sata controller while I had the server down. Thanks again! Link to comment
