Teixeira Posted October 23, 2018 Share Posted October 23, 2018 For the last couples of weeks i had to restart my server all 2 days because my shares disappears. After a reboot everything is fine again. The first time this happened i noticed that my ram was full. But i haven't seen this happen again since then. My Linux VM stays operational since its on a seperate SSD outside the array. How can prevent this from happening? My second problem is that i can't get the network bridge to work properly. This leads to me not being able to connect directly to my Plex Server (in a VM). In the logs i see those lines: Oct 21 22:29:55 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Down Oct 21 22:29:55 SteelMountain kernel: br0: port 1(eth0) entered disabled state Oct 21 22:30:11 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX Oct 21 22:30:11 SteelMountain kernel: br0: port 1(eth0) entered blocking state Oct 21 22:30:11 SteelMountain kernel: br0: port 1(eth0) entered forwarding state Oct 21 22:30:12 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Down Oct 21 22:30:12 SteelMountain kernel: br0: port 1(eth0) entered disabled state Oct 21 22:30:15 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX Oct 21 22:30:17 SteelMountain kernel: igb 0000:06:00.0: exceed max 2 second Oct 21 22:30:17 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Down Oct 21 22:30:20 SteelMountain kernel: igb 0000:06:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX Oct 21 22:30:20 SteelMountain kernel: br0: port 1(eth0) entered blocking state Oct 21 22:30:20 SteelMountain kernel: br0: port 1(eth0) entered forwarding state I should say that this server was running a 4790K before and because i thought the problem was the processor/motherboard i installed my main rigs hardware - 2700X. I don't think it has something to do with the hardware. Can someone help me out? Here are my logfiles **Edit: same problems on 6.3.5 Link to comment
JorgeB Posted October 23, 2018 Share Posted October 23, 2018 Start by updating to latest stable, it's supposed to fix all or most of the nfs issues, you might also want to disable or uninstall the nerdpack plugin. Link to comment
Teixeira Posted October 25, 2018 Author Share Posted October 25, 2018 @johnnie.black I did that and its still running after 39 hours. It usually died after 48h. Will report back tomorrow! Still up. I think it's good now boss. Thanks. Link to comment
