Talonaz28272 Posted July 17, 2019 Share Posted July 17, 2019 So I'm adding this drive and I get it to a point were I can try to mount it and then it goes to showing "insert". I'm stumped can you tell me what this means. I've even tried it in other slots. disk log info: Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Unsupported sector size 520. Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] 0 512-byte logical blocks: (0 B/0 B) Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] 520-byte physical blocks Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Write Protect is off Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Mode Sense: cf 00 10 08 Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Write cache: disabled, read cache: enabled, supports DPO and FUA Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Unsupported sector size 520. Jul 16 23:39:59 FS kernel: sd 1:0:10:0: [sdl] Attached SCSI disk Jul 16 23:40:25 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:10 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:10 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:11 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:12 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:13 FS emhttpd: device /dev/sdl has size zero Jul 16 23:42:14 FS emhttpd: device /dev/sdl has size zero Thank You For Your Time And Help Tim Link to comment
trurl Posted July 17, 2019 Share Posted July 17, 2019 You should ask on the Unassigned Devices plugin thread. Link to comment
