JohnGaltLine Posted December 28, 2019 Share Posted December 28, 2019 I'm unsure if the Dynamix System Temp plug in simply doesn't support my old hardware, or if there is some configuration I need to adjust somewhere. After installing the plug in, all temps are simply reported as "-48 C" at all times. Running a Supermicro H8DA3-2 with dual Operon 2435's (six core 2.6GHz) Unraid version 6.8.0, (though I had this same issue on 6.6.6 previously) The driver found for the sys temp plug in is: w83627hf This is my first post here, so if I need any other information, let me know. My server is a rather large mis-match of hardware assembled on the cheap, but I'm not sure that that should matter here. Over all it's not a huge issue, been running a year with it like this, but just replaced my CPU coolers with some with quieter fans and was curious what they run at now. Link to comment
JorgeB Posted December 28, 2019 Share Posted December 28, 2019 Please use the plugin support thread instead: Link to comment
