qmatic Posted April 30, 2020 Share Posted April 30, 2020 So after reading the wiki, I’ve figured my split levels are wrong. I still need help understanding it and setting it optimally for my shares. i have my media shares set up as the following: movies\movie name\movie file for this setup, if I want all movie names folder to be on the same disk until it has to move onto a second disk (high water), I would set it to level 1 or top level correct? If i have more than 1 file in the folder such as a .nfo file, would level 1 still work because split level only pertains to folders? for shows I have it on another share as: shows\tv show name\season\episodes if I wanted my tv show folders to be on the same disk while seasons can be split up, I would set it to level 2 correct? Also, since my initial setup was wrong, is there a plugin to fix this by moving the folders to the correct disks? Quote Link to comment
JorgeB Posted April 30, 2020 Share Posted April 30, 2020 4 minutes ago, qmatic said: If i have more than 1 file in the folder such as a .nfo file, would level 1 still work because split level only pertains to folders? correct 4 minutes ago, qmatic said: if I wanted my tv show folders to be on the same disk while seasons can be split up, I would set it to level 2 correct? correct 4 minutes ago, qmatic said: Also, since my initial setup was wrong, is there a plugin to fix this by moving the folders to the correct disks? There are the diskmv/consolidate scripts but they might not work on current releases due to permissions. Quote Link to comment
qmatic Posted April 30, 2020 Author Share Posted April 30, 2020 Thanks I understand it a bit better now. Out of curiosity, what would happen if I set my movie share to say level 4? Quote Link to comment
JorgeB Posted April 30, 2020 Share Posted April 30, 2020 8 minutes ago, qmatic said: Out of curiosity, what would happen if I set my movie share to say level 4? Any files written above that level would be split to any disk based on the share's allocation method. Quote Link to comment
