Dizzy810 Posted July 13, 2020 Share Posted July 13, 2020 Help! I am having problems with one of my drives. It started a couple months ago after an upgrade. Drive 7 wouldn't mount. After several times of swapping cables and reseating connectors it finally worked. Cue to yesterday. We had a power outage that lasted several hours. My server is on a UPS so it was properly shut down. But when I powered it back on Drive 7 was missing again. So I figured it had probably given up the ghost and ordered a new drive off amazon. Today I installed the new drive and booted up and the new drive isn't showing in unassigned devices. So I shut it back down and opened the case back up and swapped the power and sata with one of the other drives. Booted up and still no Drive 7. Shut back down and removed the new drive and reinstalled the old drive and still no Drive 7. Put the new drive back in and still nothing in unassigned devices. Tried new sata cable, new drive, different power connector, different sata port. Don't know what else to try. What am I missing here? tower-diagnostics-20200713-1557.zip Quote Link to comment
trurl Posted July 13, 2020 Share Posted July 13, 2020 1 hour ago, Dizzy810 said: What am I missing here? Power Supply? Quote Link to comment
Dizzy810 Posted July 13, 2020 Author Share Posted July 13, 2020 37 minutes ago, trurl said: Power Supply? But why would only one drive have the problem? And I swapped the power supply cables with another drive and Drive 7 is still the one with a problem. Quote Link to comment
trurl Posted July 14, 2020 Share Posted July 14, 2020 Have you tried booting in SAFE mode? Many of your plugins are out-of-date. Quote Link to comment
Dizzy810 Posted July 14, 2020 Author Share Posted July 14, 2020 Tried booting into safe mode and still couldn't see the drive. Without the unassigned devices plugin not much I could do anyway. I did go ahead and update all my plugins and still nothing. Quote Link to comment
