Jump to content
6.9.0-beta25 - wrong mount point for second cache pool
I created a second cache pool for my nvme drive. The mounting point is /mnt/nvme .
Disk log:
Jul 31 13:14:02 UnraidServer emhttpd: PNY_CS3030_1TB_SSD_PNY10200004940301CEB (nvme0n1) 512 1953525168
Jul 31 13:14:02 UnraidServer emhttpd: import 32 cache device: (nvme0n1) PNY_CS3030_1TB_SSD_PNY10200004940301CEB
Jul 31 13:14:44 UnraidServer emhttpd: writing MBR on disk (nvme0n1) with partition 1 offset 2048, erased: 0
Jul 31 13:14:44 UnraidServer emhttpd: re-reading (nvme0n1) partition table
Jul 31 13:14:45 UnraidServer kernel: nvme0n1: p1
Jul 31 13:14:45 UnraidServer emhttpd: shcmd (1224): /sbin/wipefs -a /dev/nvme0n1p1
Jul 31 13:14:45 UnraidServer root: /dev/nvme0n1p1: 4 bytes were erased at offset 0x00000000 (xfs): 58 46 53 42
Jul 31 13:14:45 UnraidServer emhttpd: shcmd (1225): mkfs.xfs -m crc=1,finobt=1 -f /dev/nvme0n1p1
Jul 31 13:14:45 UnraidServer root: meta-data=/dev/nvme0n1p1 isize=512 agcount=4, agsize=61047598 blks
Jul 31 13:14:46 UnraidServer emhttpd: shcmd (1227): mount -t xfs -o noatime /dev/nvme0n1p1 /mnt/nvme
Jul 31 13:14:46 UnraidServer kernel: XFS (nvme0n1p1): Mounting V5 Filesystem
Jul 31 13:14:46 UnraidServer kernel: XFS (nvme0n1p1): Ending clean mount
I changed the cache pool for the user share 'system' to nvme.
In the docker settings the value of 'Docker vDisk location' is '/mnt/user/system/docker/docker.img'.
I installed a new docker container.
If i now browse /mnt/nvme there is no file. The system directory is on /mnt/cache.
I disabled docker and started the mover, but nothing happens.
The docker vDisk is on: /mnt/cache/system/docker/docker.img
Docker settings: /mnt/user/system/docker/docker.img
User share 'system' cache pool: nvme
nvme mount point: /mnt/nvme
The docker container run without any problems.
Do i anything wrong or is this a bug?
Link to comment
If system was already on cache just changing the settings won't move it. You will have to go to Settings - Dockers and disable them so you can move system yourself.
If you want more advice post your Diagnostics.
This thread has been copied to General Support since it doesn't seem to be a bug.
Link to comment
  Only 75 emoji are allowed.
  • Create New...
