GalacticSpines Posted November 7, 2020 Share Posted November 7, 2020 (edited) I keep getting a Disk 2 Read Error from Fix Common Problems. I have run SMART extended self-test on all my disks and I'm attaching the Diagnostics. I'm trying to see where SMART picks up an error, but clearly I'm not that clued up on SMART errors. Can someone maybe have a look and let me know if I have a bad drive. deathstar-diagnostics-20201106-2201.zip Edited November 7, 2020 by GalacticSpines Quote Link to comment
JorgeB Posted November 7, 2020 Share Posted November 7, 2020 GUI is showing 1 error for disk2, until you reboot or clear the errors FCP will alert about that, disk itself looks OK so it could be a connection issue, keep monitoring. Quote Link to comment
GalacticSpines Posted November 7, 2020 Author Share Posted November 7, 2020 Thanks for the reply, I'll reboot and keep monitoring. Quote Link to comment
