Wireless Popcorn Hour coupled with Unraid
That is it - just put '*(rw)' [or even just '*®' if you never wish to write via nfs] in the 'Export (NFS):'  box under 'Movies'.
It worked!  Thanks again for all the help.  As I thought the wireless is a little hit or miss.  The DVD's appear to playback mostly fine.  The BR's though come with stutter.  I suspect I may just need to introduce a powerline or coax solution.
The only other issue I seem to have left is I thought the cover art and other information would automatically be downloaded based on the folder structure I've created from the beginning.  All my movies are listed that are on the share, but they are only seen as folders and there isn't any cover art.  I click on the folder and the movie starts to play.  The instructions say an internet connection is needed, but I obviously have that.  From what I'm reading I'm starting to have the impression a local hard drive must be connected to the PCH, but I hope that isn't the case to get only cover art because that was part of the attraction to this solution.  Any thoughts?
Great!  Good news.
In order to see cover art, you will need to run one of the jukeboxes - either NMJ which comes built-in in to the PCH firmware, or one of the third-party ones.
However, we are now getting into discussions about PCH operation, which is no longer related to unRAID.  I suggest that you take this to the PCH forums.
Understood.  Thanks again for the help.
