Help with rsync and deltacopy
It's standard chmod "funky mode" syntax (as opposed to the more obvious numeric mode).
Basically:
D for directory, F for file
ugoa for user, group, other, all
+ or - for set or clear
rwx for read, write, execute
Try googling chmod man.
Thanks again for all your help cyrnel.  I think I finally have it working the way I want it.
I've done some more experimenting and what I've come to understand is that you cannot have a space in the path when defining a module.  For example I tried this module and rysnc command combination just for kicks:
[test1]
path = /cygdrive/c/Users/John/"Saved Games"
read only = true
transfer logging = yes
rsync -avP --delete --chmod=Fo-X 192.168.1.152::test1 /mnt/user/photobackups/"Saved Games"/
This did not work. I got the same "chdir failed" error I had gotten previously and if you look back at the dir listing for c:/Users/John/ you'll see that a Saved Games directory does exist.
However if I use this module and rsync command combination it works (just simply taking cyrnel's advice and driving up the tree so that I do not have any spaces in the module path).
[test1]
read only = true
rsync -avP --delete --chmod=Fo-X 192.168.1.152::test1/"Saved Games" /mnt/user/photobackups/
That code works. It created a Saved Games directory in /mnt/user/photobackups/ and copied all the flies from c:/Users/John/Saved Games/ and places it in /mnt/user/photobackups/Saved Games/. I think I may finally understand this.  ;D
Good deal!
If I recall, the code that reads rsyncd.conf and builds modules essentially treats those lines as #defines; it isn't like shell. You could hard-code your module in a recompiled rsync but that's getting desperate. Better to do as you are.
