April 5, 20242 yr There is a plugin for Tasmota devices Is there a possibility to create the same plugin but with support for devices with Esphome?
July 13, 20242 yr YES! I've been slowly moving all my devices from Tasmota to ESPHome now that libreTiny is around and I can now use the Beken chips, and this is the one thing that I'm missing. It kind of worked with OpenBeken when I was using that for the beken chips. Surely it's possible to come up with something.
July 13, 20242 yr On 4/5/2024 at 8:08 PM, Vitek said: Is there a possibility to create the same plugin but with support for devices with Esphome? I would rather recommend that you set up Homeassistant and track the data there because you have much more granular control than in a plugin on Unraid.
