Slow speed with turbo write
8 hours ago, unraid_user11 said:
So that I can learn, where can you see the hard limit of 110MB/s in the above data?
All the diags show writes speeds around that value.
I see that most disk are pretty full, to which disk were you writing? Disks are considerably slower in the inner sectors
  • 2 months later...
Usually disk5
Disk is like 70% used, so that can be normal, it should be noticeably faster writing to an empty disk, assuming no other bottlenecks.
Fair enough, I will try again on an empty disk. Appreciate the guidance!
  • 3 months later...
I tried moving large files from the cache to a new 22TB drive with less than 25% usage and still getting transfer speeds of less than 150 MB/s. What could possibly be causing this bottleneck???
Edited by unraid_user11
Controller? Run the diskpeed container test, and post the results for both the disks and the controller.
