[GUIDE] Setup Real-Debrid for Plex Using CLI_Debrid, Rclone, and Zurg
2 hours ago, scott2020 said:
Saw this on reddit after I downloaded 3TB in about 10 days...  Turn off Media analysis,
Media Analysis. It's in Settings -> Scheduled Tasks.
Also Video preview thumbnails & intro/credit detection
If these are enabled in Plex, it will download the whole file.  So I had 3TB of crap at RD and downloaded it all for analysis.
If you are on a capped data ISP plan, this is bad.
EDIT:  A few more details.   https://github.com/itsToggle/plex_debrid/wiki/Setup-Guides#2-setup-plex-2
Omg, will that help Plex and or CLI debrid from locking up my server. Had to hard reset this morning and not sure which did it.
  • Replies 58
  • Views 76.8k
  • hernandito
    hernandito
    Go to Overseer On the search bar type the name of a Movie you know is not in your collection. Click the Request button:   The below screen will pop up. Notice that it tells you (i
  • hernandito
    hernandito
    Apologies.... I forgot to change the repo to public. It is fixed.
  • missing screenshots if needed
Anyone a clue why Andor is showing with blacklsited icon (red dot) and won't download?
It's not in my blacklist...
It's also showing up in the unreleased section on cli_debrid
I have gotten everything working fairly well over the past couple of weeks. However, it seems like the debrid links go "stale" consistently after a week. Doesn't matter what the content is, after a week the file cannot be accessed from the zurg mount. I just added new media to test and I can directly access it, however anything a week or 2 old I cannot. I confirmed it still exists with DMM. Any suggestions?
Hey great guide, just got mine setup and everything seems to be working correctly, however I have one "issue" that really isn't a big deal but it's bugging my ocd. So I copied your "best down from 4k" for the version, when cli grabs the request it's adding both a 4k version and a 1080p version to debrid. How would I get it to stop adding both and only use the best quality one it finds?
Hey, good evening. Do you have more than one scraper setup?
  • 6 months later...
This is very cool - I looked for this type of guide in 2024 with no luck. Thank you so much OP for spending the time to document it. Umm try it soon and report back!
I'm wondering how easily it would be to create a script which can check tautulli loge and automatically download TV series/movies which is watched on another server to the RD overseer created here? Would be a neat little backup server.
EDIT: after some searching and finding dechyphaar.... I also found DUMB in CA which seems like a all in one RD suite which can do this entire guide but as an automated process. Is this guide outdated and what is the experience like with DUMB?
  • 3 months later...
Seems real debrid has had to remove lots of cached files due to copyright.
I’m migrating to torbox, but seemingly can’t use CLI_debrid for that yet.
Tried the DUMB stack but not arrived at a stable combination yet.
Anyone had any success?
  • 2 months later...
Trakt has updated it OAuth setting to use a 43 digit Client ID instead of 64. CLI_Debrid has error checking expecting a 64 character Client ID. Hence the 43 digits is being rejected.
This renders the setup of cli_Debrid impossible until this error checking is updated.
