Unraid randomly hard resets after faulty drive was replaced and then freeze at post
Unraid randomly hard resets after faulty drive was replaced and then freeze at post and replaced flash drive replaced both but something is wrong still cant figure out any clues to what is causing it
tower2-diagnostics-20250405-1650.zip
Do you mean the server reboots by itself? If yes, that's almost always a hardware issue.
what hardware would cause it run fine for days and then just crash randomly and freeze at post just not sure what would cause that. never diagnosed something like that. usually  its predictable in my experience its immediate or related to high usage or something. there is no predictability it will run for a week or two with no issues i think there is corruption or something or vm related.
Could be multiple things, does it just crash or actually reboot by itself?
crashes then when i go look at it its frozen on post screen
Unfortunately, there's nothing relevant logged, and if the server reboots by itself it's almost always hardware like mentioned, since you have multiple RAM sticks, try using the server with just one, if the same try with a different one, that will basically rule out bad RAM.
have you guys ever seen a 9305-24i IT Mode 24-Port SAS 12Gb/s PCI-E 3.0 Controller Card cause computer to do this because i think that was the issue
Don't think so, but it's not impossible.
everything seems to be running smoother and snappier so hoping that's it.
ok happend agian my motherboard supports ecc memory and i have udimm ecc memory installed just wanted to see if there is a way to test memory that way or is it just a guessing  game it seems to be right around 3 day mark of running fine then boom it reboots to freeze at post.
Since you have multiple RAM sticks, try using the server with just one stick, if the same try with a different one, that will basically rule out bad RAM.
Ok I've narrowed it down a little it's constantly around 3 Days disabled zfs cache pool changed it to btrfs but didn't format it and now it didn't hang at post when it reset so I formated cache drive going to see if it is software related with that partition. in my experience hardware isn't this predictable trying not to spend 150$ per stick of memory without 100 percent knowing its memory tried each memory stick same issue gonna check if there is a second syslog that might help
Edited by hoflande
There's nothing on that syslog other than syslog server related messages.
That's why I recommended testing with one stick at a time, no need to spend money for that.
tested one stick at a time all cause it to crash bought new memory still crashes then unraid is telling me my flash drive is corrupted. orderd new power supply still crashes. so now i ordered new motherboard hoping that is it if not its a bad cpu is my guess its weird with new memory it lasts a little longer before it crashes you know if am5 cpus have isues like this not sure if thats whats next to try
tower-diagnostics-20250503-2142.zip
got  syslogs  from usb and they are bigger hopefully there is some clue
syslog syslog-previous
So I have narrowed it down to being vm related if I don't start vm it runs for days if I start vm it crashes within 24 hours not sure what to do I tried what you posted it did seem a little better maybe like 2 hours longer but still related to vm anything in my diagnostics to show vm related issues
Post diagnostics with the array started in normal (not maintenance) mode.
Unlikely to be the cause of crashes, but your "default shares" have files on the array.
https://docs.unraid.net/unraid-os/manual/shares/user-shares/#default-shares
appdata                           shareUseCache="prefer"  # Share exists on cache, disk1, disk2, disk9, disk15, disk17, disk22
domains                           shareUseCache="only"    # Share exists on cache, disk6
isos                              shareUseCache="only"    # Share exists on cache, disk1, disk2, disk3, disk4, disk15, disk16, disk19, disk20, disk21, disk22
system                            shareUseCache="prefer"  # Share exists on cache, disk1, disk2
Better if these have all files on cache or other pool, with nothing on the array, so Docker/VM performance isn't impacted by slower array reads and especially writes, and so array disks can spin down since these files are always open.
You have a lot of disks. Are you sure there isn't some power problem?
Yes I checked power supply with a cheap tester from Amazon and  it says a PG 510ms is the only issue I also bought a new Asus power supply 800watt still crashed so I don't think that is the issue also it's in a super micro 4u server so it has two power supplies. I will try that thanks.
So I've replaced memory CPU motherboard power supply not hardware I had to switch CPU settings in vm to emulated no more hard resets
