September 4, 201214 yr So i'm a tad confused as to what is causing my issue Pretty much like a few people complaining on here I am only getting write speeds of max 24MB/s to my server (transferring Blueray rips) Hold on, that's the max speed you will get writing to parity I see some of you yelling at me hearing this complaint over and over again. Yes that's true, but not when you have a cache drive setup. I have my HP Microserver N36L set to 1000Full A brand new D-Link 8GB switch (DGS-1008D) inbetween And Windows 7 box set to 1000Full Have replaced both sets of cables going to the new switch with 1xCat5e and 1xCat6 patch cables (borrowing permanently from work Like I said before have Cache setup and also Cache dirs turned on as well. After copying said files to the server it even tells me there is pending cache. So i'm a bit confused as to where I have gone wrong (If I even have) and how I can fix it. I have also attached the syslog as well. STATS: unRAID Version: unRAID Server Plus, Version 5.0-rc6-r8168-test Motherboard: - Processor: AMD AthlonTM II Neo N36L Dual-Core - 1.3 GHz Cache: L1 = 256 kB L2 = 2048 kB L3 = 0 kB Memory: 4 GB - DIMM0 = 1333 MHz DIMM1 = 1333 MHz Network: 1000Mb/s - Full Duplex ifconfig: eth0 Link encap:Ethernet HWaddr b4:99:ba:b5:36:6d inet addr:192.168.0.11 Bcast:192.168.0.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:346422102 errors:0 dropped:92 overruns:0 frame:542 TX packets:243567035 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:404375785614 (376.6 GiB) TX bytes:294684931961 (274.4 GiB) Interrupt:18 ethtool eth0: Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: Symmetric Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Link partner advertised pause frame use: Symmetric Receive-only Link partner advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 1 Transceiver: internal Auto-negotiation: on MDI-X: off Supports Wake-on: g Wake-on: g Current message level: 0x000000ff (255) Link detected: yes hdparm: root@Tower:~# hdparm -tT /dev/[hs]d? /dev/hdb: Timing cached reads: 2032 MB in 2.00 seconds = 1016.42 MB/sec Timing buffered disk reads: 286 MB in 3.01 seconds = 94.99 MB/sec /dev/sda: Timing cached reads: 2162 MB in 2.00 seconds = 1081.15 MB/sec Timing buffered disk reads: 56 MB in 3.09 seconds = 18.15 MB/sec /dev/sdb: Timing cached reads: 2238 MB in 2.00 seconds = 1119.59 MB/sec Timing buffered disk reads: 388 MB in 3.01 seconds = 129.07 MB/sec /dev/sdc: Timing cached reads: 2364 MB in 2.00 seconds = 1182.39 MB/sec Timing buffered disk reads: 268 MB in 3.00 seconds = 89.29 MB/sec /dev/sdd: Timing cached reads: 2192 MB in 2.01 seconds = 1090.36 MB/sec Timing buffered disk reads: 362 MB in 3.00 seconds = 120.62 MB/sec /dev/sde: Timing cached reads: 1992 MB in 2.00 seconds = 995.99 MB/sec Timing buffered disk reads: 158 MB in 3.75 seconds = 42.13 MB/sec syslog-2012-09-04.zip
September 5, 201214 yr Author All 3 of my shares are set-up to use Cache. And like I said before the cache is working like it should be moving stuff at 3am (Or what ever the time has been set I forget)
September 5, 201214 yr Your system is too slow for unraid to work properly. Get a faster cpu. Even though unraid claims it can run on spare hardware you have lying around or hardware that is obsolete, that does not mean it will work at its best. If you want any performance by todays standards, get modern, faster hardware.
September 5, 201214 yr Author Your system is too slow for unraid to work properly. Get a faster cpu. Even though unraid claims it can run on spare hardware you have lying around or hardware that is obsolete, that does not mean it will work at its best. If you want any performance by todays standards, get modern, faster hardware. Jowi you are wrong. My system runs perfectly fine with the hardware I am running. Just because the CPU isnt such a high number doesn't mean its affecting what issue I am having. The issue ended up being with a bios setting. You need to modify the bios, as my cache drive was running off the sata port on the motherboard it was limited as to what it could ran at. As mentioned in the post below. Although myn didnt say 'SATA IDE combined mode' it said something along the lines of 'SATA ports 5/6 IDE' Enabled. http://lime-technology.com/forum/index.php?topic=11585.240
September 5, 201214 yr I assumed your basic settings were right to begin with. So what speeds do you have now? On a fast machine you should get about 100MB/s copying over the network to your cache disk... writing to a parity protected user share should be at about 40 to 50 MB/s...
September 5, 201214 yr I assumed your basic settings were right to begin with. So what speeds do you have now? On a fast machine you should get about 100MB/s copying over the network to your cache disk... writing to a parity protected user share should be at about 40 to 50 MB/s... FYI I had a Celeron 430 on a X7SBE MB and got close to these speeds. I've since moved on to VMs on ESXi for unRAID. The biggest difference I saw when I went with a faster processor was the GUI responsiveness. I went from the 1.8Ghz single core Celeron to a 3.2Ghz single core VM. It got faster in unMENU and the unRAID GUI. The access speeds were 75-90MB/s to cache and 35-45MB/s to protected array on my Celeron 430 based unRAID install. I didn't have many plugings no SAB/Transmission ect... Just a few for server health and status displays.
