June 2, 201313 yr From that discussion I gather that a proper solution would be a 64-bit kernel (still with 32-bit user if needed). I can't try that though, only Limetech would know how to mod their driver to compile in a 64-bit kernel. I seriously hope that this is the "fix" they are talking about. Anything short of that won't be a real fix. Uhm, I've been running unraid on 64bit Slackware for nearly 2 years now. Its not that difficult, and I've even updated the wiki on the subject a couple of times. Most of the time I never even changed the drivers, they compiled as is and functioned fine. It was only when I was trying out different cutting edge kernels that I had to do mods to the drivers. Of course its possible that there can be a lot more fine tuning done with the MD drivers if you only target 64bit.
June 2, 201313 yr Author From that discussion I gather that a proper solution would be a 64-bit kernel (still with 32-bit user if needed). I can't try that though, only Limetech would know how to mod their driver to compile in a 64-bit kernel. I seriously hope that this is the "fix" they are talking about. Anything short of that won't be a real fix. Uhm, I've been running unraid on 64bit Slackware for nearly 2 years now. Its not that difficult, and I've even updated the wiki on the subject a couple of times. Most of the time I never even changed the drivers, they compiled as is and functioned fine. It was only when I was trying out different cutting edge kernels that I had to do mods to the drivers. Of course its possible that there can be a lot more fine tuning done with the MD drivers if you only target 64bit. That's promising news Brit! @Barzija, Did you try with lowering memory to 8GB? i.e. boot with the mem= parameter?
June 3, 201313 yr @WeeboTech: Yes, I plucked out half the RAM. Still got copy-timeouts with 8GB. Any chance you can reduce your RAM to 4GB? If so, this might fix the copy-timeouts.
June 3, 201313 yr Any chance you can reduce your RAM to 4GB? If so, this might fix the copy-timeouts. Oh, yes, I know that that will do it. It just pisses me off to have 16GB RAM wasted. (I remember fondly the time when I paid $800 for a 16MB upgrade.) I understand your frustration. I felt similar with my 4x 8GB sticks, however fortunately my motherboard allows for ESXi (free) to virtualize unRAID as a VM and limit RAM to 4GB. If you cannot run ESXi with your equipment, I'm hopeful that 5.0-rc13 will fix your problem. I had the same copy-timeout type problem with large files....until I was able to find a way to mitigate the high amount of RAM issue (ESXi and an unRAID VM in my case). Hopefully 5.0-rc13 is the silver bullet and fixes the copy-timeouts.
June 3, 201313 yr I started with Johnm's ESXi "how-to" here: http://lime-technology.com/forum/index.php?topic=14695.0 Also, BetaQuasi's post here is very helpful (ESXi 5.x - pre-built VMDK for unRAID): http://lime-technology.com/forum/index.php?topic=26639.0 In my ESXi box (32GB RAM) I'm currently running: unRAID VM, pfSense VM, WIN7 VM and an Ubuntu VM. I essentially knew nothing about ESXi until a few months ago...but so far it's been rock solid and it was fairly easy to ramp up to install/use...plus the unRAID community support is excellent!
June 3, 201313 yr Author I didn't get that much RAM just for nothing. I was planning to run some other things on top of unRaid. But now you get me thinking, ESXi should be a cleaner way to do that. ESX is cleaner, unless what you are running is small very normal unix apps. I.E. ssh,bind,tftp,ftp, etc,etc.
