luca2 Posted April 5, 2015 Share Posted April 5, 2015 Hi, I am running 6b14b and when tries to install dmacias plugin I realized I have no connection to internet. I attach a pic of my network setup. -router1: provides internet access from wan; -router2: provides lan2 (to pc, unraid1 and unraid2) I never had problems before with this setup. My pc now has internet without a problem. But my unraid2 cannot ping anything outside the lan. I actually can ping all devices in the lan. With the same setup I had also Vm´s running on top of unraid2 and they did connect to internet too. Anyone can give some advice on what should I review? Rgds. Link to comment
CHBMB Posted April 5, 2015 Share Posted April 5, 2015 So you've had VMs running prior to trying to install dmacias' plugin? What's changed between then and now? Setup a bridge? Although you'd need one to run a VM no? Link to comment
luca2 Posted April 5, 2015 Author Share Posted April 5, 2015 So you've had VMs running prior to trying to install dmacias' plugin? What's changed between then and now? Setup a bridge? Although you'd need one to run a VM no? I had an unclean shutdown due to browser not being accesible. Bridge is created now. The problem is dmacias´s plugin cannot be downloaded. Link to comment
CHBMB Posted April 5, 2015 Share Posted April 5, 2015 That's really odd, so did you create the bridge after the shutdown and then lose internet access, the reason I ask is because I've had issues in the past with bridges and changes in IP addresses.... Long story! Link to comment
