Nice small unRAID compatible flash drive
The only downside of something that thin is the possibility of lateral breakage.
...well, that is a valid statement I heard so often when I did my research for my first build.
Obviously, if you want easy access to the Stick, you'll have to keep it on the outside of the box.
The smallest I could find is already discussed here.
Another option of course is to put it INSIDE.
Physical Access to the stick is not a priority 1 requirement, I'd think.
If your MoBo has no Type-A slot, you could try and use one of these pictured below,
which will convert a USB Pin-Header into two small Slot-A connectors.
I really like how that adapter looks. Where do you get it from? I looked on new egg and everything I've found so far looks like a dongle.
...I have to admit that I actually cannot memorize where I did get it from.
Definitely not from newegg or others because I am located at the wrong
side of the planet for that.
Scan do a similar one: http://www.scan.co.uk/products/lycom-ub-109-internal-motherboard-header-2x5-pin-usb2-header-to-2-usb-a-type-adapter
2-port USB-motherbaord to USB-A adapter board, slightly different than the one Ford Prefect found:
   http://www.amazon.com/USB-HEADER-PIN-DUAL-TYPE-ADAPTER/dp/B003UIM142
Another 2-port adapter:
   http://www.amazon.com/Port-USB-Motherboard-Header-Adapter/dp/B002GNU2V6
1-port USB-motherboard to USB-A short adapter cable:
   http://www.amazon.com/StarTech-Motherboard-4-Pin-Header-USBMBADAPT/dp/B000IV6S9S
