damato300x7 Posted January 13, 2018 Share Posted January 13, 2018 I am getting a Call Traces error in Fix Common Problems. Here is the exact error: "Your server has issued one or more call traces. This could be caused by a Kernel Issue, Bad Memory, etc. You should post your diagnostics and ask for assistance on the unRaid forums" I have attached my diagnostics. Thanks dms-diagnostics-20180113-1011.zip Link to comment
JorgeB Posted January 13, 2018 Share Posted January 13, 2018 SASLP driver crashed, you might want to look at getting that replaced with an LSI. Link to comment
damato300x7 Posted January 13, 2018 Author Share Posted January 13, 2018 Which do you think is the most out of the box compatible with at least 8 ports? Link to comment
JorgeB Posted January 13, 2018 Share Posted January 13, 2018 Any LSI with a SAS2008/2308/3008 chipset in IT mode, e.g., 9201-8i, 9211-8i, 9207-8i, 9300-8i, etc and clones. Link to comment
damato300x7 Posted January 13, 2018 Author Share Posted January 13, 2018 ok. Just bought a LSI SAS 9207-8i on eBay. Should be here this week. Thanks for your help Link to comment
