limetech Posted January 22, 2018 Share Posted January 22, 2018 7 minutes ago, big.burlinski said: Appreciate it! It's stopped but not powered down at this time. I do have flash drive backed up I have to set up a 6.3.5 server with some storage and test... might take a few hours. Link to comment
big.burlinski Posted January 22, 2018 Author Share Posted January 22, 2018 Ok, really appreciate it! I will check in a little later! Link to comment
big.burlinski Posted January 23, 2018 Author Share Posted January 23, 2018 I'll have a drive to use in a day or two, I decided to bite the bullet and repurpose a 2TB drive in a USB enclosure that I had with backups on it and in the process of downsizing and rearranging that now, then I'll preclear it in the other server. It's already in there in Unassigned devices. If everything continues to go well I might even be able to start the preclear tonight before bed time :-) Reminiscing, that reminded me this is how this whole unRAID journey started, I kept looking at all those USB drives I had and said this is kinda getting ridiculous lol. Thanks again for all the help this really is the greatest forum and product support.! Link to comment
limetech Posted January 24, 2018 Share Posted January 24, 2018 4 hours ago, big.burlinski said: I'll have a drive to use in a day or two, I decided to bite the bullet and repurpose a 2TB drive in a USB enclosure that I had with backups on it and in the process of downsizing and rearranging that now, then I'll preclear it in the other server. It's already in there in Unassigned devices. If everything continues to go well I might even be able to start the preclear tonight before bed time :-) Reminiscing, that reminded me this is how this whole unRAID journey started, I kept looking at all those USB drives I had and said this is kinda getting ridiculous lol. Thanks again for all the help this really is the greatest forum and product support.! Sorry for the non-response. I've been having server issues of my own Do you have flash backups from before you did any kind of 'New Config' operation? Link to comment
big.burlinski Posted January 24, 2018 Author Share Posted January 24, 2018 1 hour ago, limetech said: Sorry for the non-response. I've been having server issues of my own Do you have flash backups from before you did any kind of 'New Config' operation? yes I did back up the flash drive so I can restore Link to comment
big.burlinski Posted January 24, 2018 Author Share Posted January 24, 2018 14 hours ago, big.burlinski said: yes I did back up the flash drive so I can restore Just to be sure, I just read up on the flash drive, I took the backup with the array stopped, just before I did anything like new config or anything, basically the first thing I did. It seemed that at that time, with the system powered up, but never started and no rebuilds or parity checks run (actually it would not have let me) Disk7 was disabled, but present in the config, and Disk5 was disabled and showed no device, with the original serial # below that as missing. So probably tomorrow I will be doing this (preclear on the replacement disk 5 is still in the first read stage): To resolve this what you'd need to do is this. 1 - Get or find a replacement for disk5. Should be same size as old disk5. 2 - Do a new config and where disk5 had been, insert the new disk 3 - Start the array, trusting parity 4 - Immediately stop the array. Remove replacement disk5 from slot5, leaving the slot empty. 5 - Start the array. (UnRAID will now start and be emulating disk5) 6 - Look at disk5. See if it looks generally good. Hopefully it will. But if disk7 had gotten updates while it was being emulated, it might appear unformatted. But there is still hope - especially since you are likely using RFS file system, which is best for recovering data from situations like this. 7 - Either way, stop the array, reassign a new disk to slot5 (doesn't have to be the same one you used in steps 1 and 2), and restart the array. 8 - unRAID will rebuild disk5 To restore my backed up flash drive, should i copy everything, or just the config folder? Should I do anything special with the super.dat file? (I think I should replace super.dat because it has now changed when I did the new config) but maybe unRAID can just make a new one after the new config. I probably will go ahead and rebuild disk5 after that why not :-) Thanks you guys for your support! Link to comment
JorgeB Posted January 24, 2018 Share Posted January 24, 2018 1 minute ago, big.burlinski said: To resolve this what you'd need to do is this. You can and should do the procedure Tom (limetech) posted about using the invalid slot command, this works with a new disk, it's only not working for now with an empty slot. Link to comment
big.burlinski Posted January 24, 2018 Author Share Posted January 24, 2018 17 minutes ago, johnnie.black said: You can and should do the procedure Tom (limetech) posted about using the invalid slot command, this works with a new disk, it's only not working for now with an empty slot. Ok, good I will! I did have a question in there about restoring the flash drive backup :-) Link to comment
JorgeB Posted January 24, 2018 Share Posted January 24, 2018 10 minutes ago, big.burlinski said: Ok, good I will! I did have a question in there about restoring the flash drive backup :-) You don't need to restore, do another new config, assign any missing disks, including the new disk5, run the invalid slot command and start the array to begin the rebuild. Link to comment
big.burlinski Posted January 24, 2018 Author Share Posted January 24, 2018 3 minutes ago, johnnie.black said: You don't need to restore, do another new config, assign any missing disks, including the new disk5, run the invalid slot command and start the array to begin the rebuild. Ok, sounds good, appreciate it! Link to comment
