Ruthalas Posted April 4, 2018 Share Posted April 4, 2018 I recently swapped what case housed my unRAID build to make more drive bays available, etc. I got everything up and when I first powered it on I realized my dockers were missing- after a brief investigation I realized I had neglected to plug power into my two cache drives. After shutting down and connecting power, both drives show up, but as unnassigned devices rather than cache disks. What is the best way to go about resolving this? Can I force unRAID to pick them back up as cache disks, or do I need to recreate the cache and copy the content over? Potentially useful information: I mounted them, hoping they would be recognized as cache drives diagnostics-20180404-0908.zip Link to comment
JorgeB Posted April 4, 2018 Share Posted April 4, 2018 Re-assign both to the pool should bring them online, note that a new docker image was created when you started the array without them, so delete that. Link to comment
Ruthalas Posted April 4, 2018 Author Share Posted April 4, 2018 Should I delete that new docker image before I reassign them? And how do I do that? (Sorry, a bit Docker illiterate here.) Edit: I guess I am not sure where it would have been created. I am digging around to find it. Link to comment
JonathanM Posted April 4, 2018 Share Posted April 4, 2018 35 minutes ago, Ruthalas said: Edit: I guess I am not sure where it would have been created. I am digging around to find it. Settings - Docker - advanced view Link to comment
Ruthalas Posted April 4, 2018 Author Share Posted April 4, 2018 Thank you! I was able to delete the docker image it had created in the system share, and able to reassign the cache disks successfully. I appreciate the help. Link to comment
