Maticks Posted April 10, 2018 Share Posted April 10, 2018 Probably best to describe why i rebooted first. I woke up this morning to my medusa docker not responding on its webui. I checked my other dockers they were working, i tried to restart medusa docker and it wouldn’t restart. i did a quick check in dashboard and noticed that the flash docker log was at 100% i have never seen it more than 20% full ever. My Cache drive was at around 30% full, none of my hard drives are full either. I decided to reboot the box so i restarted it, my vm’s took a while but finally booted back up but dockers never started. When i click on the dockers tab, it says the docker service failed to start.. what do i do? i haven’t had this issue before. Can anyone help point me in the right direction. Link to comment
John_M Posted April 10, 2018 Share Posted April 10, 2018 33 minutes ago, Maticks said: Can anyone help point me in the right direction. Tools -> Diagnostics. Post the zip file. Link to comment
Maticks Posted April 10, 2018 Author Share Posted April 10, 2018 As attached vault-diagnostics-20180411-0841.zip Link to comment
Maticks Posted April 10, 2018 Author Share Posted April 10, 2018 i am assuming its this. but i have a heaps of space... ime="2018-04-11T07:12:08+10:00" level=error msg="garbage collection failed" error="write /var/lib/docker/containerd/daemon/io.containerd.metadata.v1.bolt/meta.db: no space left on device" module="containerd/io.containerd.gc.v1.scheduler" panic: runtime error: invalid memory address or nil pointer dereference [signal SIGSEGV: segmentation violation code=0x1 addr=0x10 pc=0x8ae367] Link to comment
Maticks Posted April 10, 2018 Author Share Posted April 10, 2018 just increased my docker image size to 30G so i can start it. looks to be working... Link to comment
Maticks Posted April 10, 2018 Author Share Posted April 10, 2018 well found the 6.1GB log file with the same entry. bit weird though.. {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445811136Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445815478Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.44582013Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.4458232Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445825713Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445829377Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445833706Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445836275Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445838856Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445843206Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445847761Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445850568Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445854268Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445858084Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445860761Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445865003Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445868597Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445871172Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445873674Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445876963Z"} {"log":"Found pihole-FTL process with PID 534 (my PID 625) - killing it ...\n","stream":"stdout","time":"2018-04-10T23:06:50.445885869Z"} Link to comment
John_M Posted April 10, 2018 Share Posted April 10, 2018 I don't use pihole. Is it misconfigured? Link to comment
Maticks Posted April 10, 2018 Author Share Posted April 10, 2018 i think the docker got an update last night with some issues. after dropping the log file and restarting the docker it still went over and created endless log errors with the wrong pid error. so i forced an update of the docker which had two updates. that fixed it. the log output is now fixed. maybe someone made a mistake and pushed an update. hrmm i think ill set my docker auto update to the weekends from now on. Link to comment
John_M Posted April 11, 2018 Share Posted April 11, 2018 I don't like auto updates, myself. I like to be informed that updates are available but I prefer to install them manually after I've read the release notes. Link to comment
