July 22, 20188 yr Hi, guys. Affter a week powered off my server today i've switched on and somehing wrong is happening. Via SSH i can access all the contents of my /mnt/user/... and i can see the array files, but in the web interface all i can see is a message saying "Array starting - Mounting disks". And i can'r start the docker application because the array it is no mounted (but via CLI the array it's up an running). Any suggestions, please? Thanks. PS: I've upgrade to 6.5.3 if it fix the problem, but i got the same results. servidor-diagnostics-20180723-0032.zip
July 22, 20188 yr Try the "Safemode" boot option when booting (Will skip your plugins) I suspect it is your Ransomware plugin giving you issues, test that by removing it or disabling it... If neither of those help, what is the results of this? df -h
July 22, 20188 yr Author I haven't booted on safe mode yet, because i'm copying some files. The first thing i saw in Fix Common Problems was the Ransomware plugin error, but i can't uninstall it from the web gui. I'll try to delete it manually in the pendrive.
