September 19, 201015 yr Author ok here is my syslog right after i reset my motherboard settings. so please dont feel irritated by the date/time syslog.txt
September 20, 201015 yr Author bwm-ng bwm-ng v0.6 (refresh 1s); input: disk IO Device Read Write Total sda: 10224.41 KB/s 6047.24 KB/s 16271.65 KB/s sdb: 5188.98 KB/s 6047.24 KB/s 11236.22 KB/s total: 15413.39 KB/s 12094.49 KB/s 27507.87 KB/s when i use copy within MC from one folder to another on the same disk
September 20, 201015 yr Author ok, i posted the syslog above. maybe you can figure something out. my go file only exists with the unMenu boot string as well as with: /boot/cache_dirs -d 4 -m 3 -M 5 -w maybe cache_dir is the reason? when ever i shutdown the server i get serveral errors regarding "chache_dir error /dev/hd[a..z] not found." well i dont use IDE drives but maybe my script is broken or i misconfigured the (or any other) plugin wrong?
September 20, 201015 yr Author naaaahh this really drives me crazy. can i somehow check if my discs performance is about normal? why is my MC only at 9-10MB/s copy speed while writing from a disc to itself? it could be a very very slow bus from the mobo, but i highly doubt it. after looking into so many other issues for weeks now (that luckily could be solved thanks to you), i really would love to just start using unRAID
September 22, 201015 yr Author today i'm back with more precise results. i finally plugged in a 1000MBit switch. (1. ) while my copy speed via 100MBit was of course only ~11MB/sec now it is only at ~16-18MB/sec if I copy from windows to my unRAID server. my switch reports 2 communicating gigabit network devices, so the connection itself should be good enough. (2.) now if I log into putty/telnet and try to copy from my one hdd to itself again, my speed isn't going higher than 16MB/sec, too. well it is an increase by 80%, but I expected something from 30-60MB/sec at least to be honest. Syslog Jan 4 14:09:14 Tower kernel: e1000e: eth0 NIC Link is Down Jan 4 14:09:14 Tower ifplugd(eth0)[1240]: Link beat lost. Jan 4 14:09:22 Tower kernel: e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX Jan 4 14:09:23 Tower ifplugd(eth0)[1240]: Link beat detected. Jan 4 14:21:21 Tower shfs: shfs_rmdir: rmdir: /mnt/disk1/abc (39) Directory not empty Jan 4 14:21:58 Tower in.telnetd[446]: connect from 192.168.178.27 (192.168.178.27) Jan 4 14:22:00 Tower login[447]: ROOT LOGIN on `pts/0' from `.' Jan 4 14:23:24 Tower shfs: shfs_rmdir: rmdir: /mnt/disk1/add (39) Directory not empty Jan 4 14:29:11 Tower in.telnetd[2727]: connect from 192.168.178.27 (192.168.178.27) Jan 4 14:29:13 Tower login[2728]: ROOT LOGIN on `pts/0' from `.' ethtool eth0 root@Tower:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 1 Transceiver: internal Auto-negotiation: on Supports Wake-on: pumbag Wake-on: g Current message level: 0x00000001 (1) Link detected: yes ifconfig eth0 root@Tower:~# ifconfig eth0 eth0 Link encap:Ethernet HWaddr 00:18:f3:c6:56:c3 inet addr:192.168.178.24 Bcast:192.168.178.255 Mask:255.255.255.0 UP BROADCAST NOTRAILERS RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1448415225 errors:0 dropped:0 overruns:0 frame:0 TX packets:655319876 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:2605991747 (2.4 GiB) TX bytes:3717581153 (3.4 GiB) Memory:ff6e0000-ff700000 My Go- file #!/bin/bash # Start the Management Utility /usr/local/sbin/emhttp & cd /boot/packages && find . -name '*.auto_install' -type f -print | sort | xargs -n1 sh -c /boot/unmenu/uu /boot/cache_dirs -d 4 -m 3 -M 5 -w AHCI is not forced. The detection setting from bios is set to automatic. I guess i could force it, but I'm not experienced enough with this. Copying from 1 hdd to another within my windows PC usually is around 63MB/sec or higher, depending of the hdds. I really hope anyone is reading this and has some ideas or tests to suggest. I so much need to get this issue done and finally start to do what i planned to do with the server. Putting it out of sight, knowing it is there and working for a looong time. Please help.
September 22, 201015 yr Log onto unRAID via telnet or on the system console. Type mc to enter midnight-commander Use it to copy from one disk to another. All your disks will be found under /mnt Copying using window's explorer has all the data going from the server to your windows PC and back, severely slowing you down.
September 22, 201015 yr Author Log onto unRAID via telnet or on the system console. Type mc to enter midnight-commander Use it to copy from one disk to another. All your disks will be found under /mnt Copying using window's explorer has all the data going from the server to your windows PC and back, severely slowing you down. Well, was my post to long? I already did that and reported it in the post above. (1. ) while my copy speed via 100MBit was of course only ~11MB/sec now it is only at ~16-18MB/sec if I copy from windows to my unRAID server. my switch reports 2 communicating gigabit network devices, so the connection itself should be good enough. (2.) now if I log into putty/telnet and try to copy from my one hdd to itself again, my speed isn't going higher than 16MB/sec, too. Short: copying data from windows to unRaid -> ~17 MB/sec copying data from unRaid to unRaid with mc -> ~16MB/sec. Edit: speed tests (using hdparm -tT) via user scripts from unMenu /dev/sda: Timing cached reads: 5658 MB in 2.00 seconds = 2832.75 MB/sec Timing buffered disk reads: 304 MB in 3.01 seconds = 101.14 MB/sec /dev/sdb: Timing cached reads: 5886 MB in 2.00 seconds = 2947.22 MB/sec Timing buffered disk reads: 304 MB in 3.02 seconds = 100.70 MB/sec /dev/sdc: Timing cached reads: 5372 MB in 2.00 seconds = 2689.02 MB/sec Timing buffered disk reads: 40 MB in 3.16 seconds = 12.68 MB/sec how could that be? Is every data going through my USB Flash? .....
September 22, 201015 yr Nothing goes through your flash drive. (sorry I missed your prior statistics) The hdparm tests are only teating raw read speeds, and only on a single disk at a time. hdparm does not test write speed. Write speed is mostly limited by the rotational speeds of the disks and the bus throughput. To see the maximum possible "write" speed you can type dd if=/dev/urandom bs=1M of=/mnt/disk1/test_file.dat count=8000 It will write a file named test_file.dat that will be 8000 Megabytes in size (8Gig) It will report the timing. There is absolutely nothing in the network involved, but you will be limited by the slower of the rotational speeds of the parity disk and of disk1. Both must spin the platters about 2 1/2 times per block of data written. Once you've created the file, you can test the raw read speed with dd if=/mnt/disk1/test_file.dat of=/dev/null bs=1M To do the same test through a user-share, just type dd if=/dev/urandom bs=1M of=/mnt/user/movies/test_file.dat count=8000 and dd if=/mnt/user/movies/test_file.dat of=/dev/null bs=1M (assuming "movies" is a valid user-share on your server) Speed through a user-share will be slower. when you were copying using "mc" from a disk to itself the time needed will be higher. Now, that one disk has to: Position the read heads to read the existing block of data Wait until the correct sector is under the read head Read the existing block 1 Position the read heads to read the block of data to be written Wait until the correct sector to be written is under the read head Read the target block 1 (at the same time the parity disk is positioning the read head to the existing parity block and then waiting until the correct sector is under the read head and then reading the sector) When both the target sector AND the parity sector are read they are xor'ed to get the new parity calculation. Then, two "writes" are issued... once to the parity disk, and one to the "target" disk. They each have to wait until the correct sector is under the write head. (Typically, between a "read" and subsequent "write" the platter must spin at least once... but it can be more if other processes move the disk head, such as the process reading the original file on the source disk) Now, the two sectors are written... but wait, the file copy is not complete, we need to move the read head back to the source file's location on the disk and wait for the correct sector to come around once more to read it. position the read heads on both the parity disk and the target disk to the sector to be read and subsequently re-written. I'm counting probably 5 revolutions of the platter on the disk being copied from and two or three on the one being copied to. Moving a disk head is a very time consuming process, waiting for a cylinder to spin under the head equally so. Even with buffering in the drives it takes time. In the mean time we've written 16Gig (8 to parity, 8 to the data disk) and read 24 Gig (8 from the source, 8 from the target, and 8 from parity) all through your motherboard's bus. That's 40 Gig of data. Joe L.
September 22, 201015 yr Author thanks for the tips. i will test all things you suggested and report my results. in the meantime can you tell me what write -speed rates a healthy system should bring up?
September 22, 201015 yr thanks for the tips. i will test all things you suggested and report my results. in the meantime can you tell me what write -speed rates a healthy system should bring up? I just corrected my prior post. The copy of random data should be from /dev/urandom, not /dev/random. (not the added leading "u" in "urandom") Joe L.
September 22, 201015 yr /here are some representative timings from my newer server. Apparantly, reading from /dev/urandom takes a LONG time. Reading from /dev/zero is much faster. In any case, I tried it with 4096 as the block size, and with 1Meg as the block size. Not too much difference. root@Tower2:~# dd if=/dev/urandom bs=1M of=/mnt/disk1/test_file.dat count=8000 8000+0 records in 8000+0 records out 8388608000 bytes (8.4 GB) copied, 2597.51 s, 3.2 MB/s root@Tower2:~# dd if=/dev/urandom bs=4096 of=/mnt/disk1/test_file.dat count=2000000 2000000+0 records in 2000000+0 records out 8192000000 bytes (8.2 GB) copied, 2517.17 s, 3.3 MB/s root@Tower2:~# dd if=/dev/zero bs=4096 of=/mnt/disk1/test_file.dat count=2000000 2000000+0 records in 2000000+0 records out 8192000000 bytes (8.2 GB) copied, 239.899 s, 34.1 MB/s root@Tower2:~# dd if=/dev/zero bs=1M of=/mnt/disk1/test_file.dat count=8000 8000+0 records in 8000+0 records out 8388608000 bytes (8.4 GB) copied, 264.704 s, 31.7 MB/s root@Tower2:~# dd if=/mnt/disk1/test_file.dat of=/dev/null bs=4096 2048000+0 records in 2048000+0 records out 8388608000 bytes (8.4 GB) copied, 89.7247 s, 93.5 MB/s root@Tower2:~# dd if=/mnt/disk1/test_file.dat of=/dev/null bs=1M 8000+0 records in 8000+0 records out 8388608000 bytes (8.4 GB) copied, 90.0364 s, 93.2 MB/s And here is my older server, wiriting to an old (and much slower) 400Gig IDE drive root@Tower:/boot# dd if=/dev/zero bs=4096 of=/mnt/disk2/test_file.dat count=2000000 2000000+0 records in 2000000+0 records out 8192000000 bytes (8.2 GB) copied, 1275.85 s, 6.4 MB/s root@Tower:/boot# dd if=/dev/zero bs=1M of=/mnt/disk2/test_file.dat count=8000 8000+0 records in 8000+0 records out 8388608000 bytes (8.4 GB) copied, 1009.16 s, 8.3 MB/s root@Tower:/boot# dd if=/mnt/disk2/test_file.dat of=/dev/null bs=1M 8000+0 records in 8000+0 records out 8388608000 bytes (8.4 GB) copied, 794 s, 10.6 MB/s root@Tower:/boot# dd if=/mnt/disk2/test_file.dat of=/dev/null bs=4096 2048000+0 records in 2048000+0 records out 8388608000 bytes (8.4 GB) copied, 757.329 s, 11.1 MB/s
October 18, 201015 yr not sure if its been solved or not, but I am experiencing slow copy speeds myself. my drive is a 20ears with pins 7/8 jumpered. using putty and the MC command I try the following. move file from /mnt/disk1/Downloads/Complete/Movies/MoieName /mnt/disk1/Movies/ I get about 10MB/s transfer speed. but if I go from say disk2 or a NTFS drive mounted using unMenu outside the array I get much faster write speeds. I guess I need a cache drive asap. -=Jason=- EDIT: using Putty at work I moved 2 large files (one 5gb and one 3gb) using MC from /mnt/disk1/Downloads/Complete/Movies to /mnt/disk1/Movies and it was lightening fast, I did't even see a speed it just did it. so im thinking my win7 laptop is some how to blame, not sure how or why if I am using putty and mc to control the server how can win 7 laptop be bottle necking my transfers.?? -=Jason=-
October 18, 201015 yr EDIT: using Putty at work I moved 2 large files (one 5gb and one 3gb) using MC from /mnt/disk1/Downloads/Complete/Movies to /mnt/disk1/Movies and it was lightening fast, I did't even see a speed it just did it. Moving a file on the SAME disk is just a matter of creating the directory entries that point to the file. It will occur in a fraction of a second. Moving a file from one physical disk to another requires you to read the source file (let's say at 80 MB/s) and reading the target data blocks to be written, and the parity blocks to be written, and then writing the data blocks and the parity blocks, all while waiting for the disk cylinders to rotate between the read, the write, and the subsequent read. Let's say the overall rate is 30 MB/s. So you have 8000 MB (8 gig) to read at 80MB/s = 100 seconds. You have 8000 MB to write at 30MB/s = 266 seconds Total time = 366 seconds or roughly 6 minutes... You're not likely to get too much better than this. It will probably take twice that if done over the LAN.
October 18, 201015 yr Joe while at home on the Lan and Win 7 I am moving the file from the same disk. /mnt/disk1/Downloads/Complete/Movies/MovieName to /mnt/disk1/Movies/ its the same disk, but at home on the win7 laptop using MC its painfully slow. at work not even on the lan but connected via putty its blazing fast. using teracopy forget about its its at 1.5-3 MB/s while mc is 10MB/s and at work its lightening fast -=Jason=-
October 20, 201015 yr I've no idea what was going on, but I've transfered several files today using mc from the same disk and its been lightening fast. does it make a different if you "copy" vs "rename/ move" as I think I might have been doing a F5 copy instead of F6 rename/move -=Jason=-
October 20, 201015 yr Yes. The data does not get copied when you rename/move on the same filesystem, only the filename and directory path are changed.
