MomentarilyEpic Posted July 3, 2019 Share Posted July 3, 2019 Installed aquantia 10gbe ethernet cards on both my unraid and my pc, I know the connection is fine because when from my pc nvme drive to unraid ram disk i get full speeds both ends. This is also confirmed by putting an nvme drive in unassigned devices and copying a 50gb file and its at full speed again either end. However for the life of me I cant figure out that no matter what my cache configuration is i only get 500mb/s write (half of what it should be) and whats worse is only 60mb/s read from cache to my pc Ive tried single sata ssd 2 sata ssd's in raid 0 and single nvme (i dont have a second one) (Tried with jumbo frames and without, like i said, i know its not the connection coz it works with ramdisk and the nvme in unassigned devices) all of these have the same speeds when adding files to cache but goes at max speed when in unassigned devices but only goes at half write and EVEN WORSE reads when in cache Link to comment
JorgeB Posted July 3, 2019 Share Posted July 3, 2019 IS that to a disk or user share? If user share try with direct IO enable (Settings -> Global Share Settings). Link to comment
MomentarilyEpic Posted July 3, 2019 Author Share Posted July 3, 2019 thats already on, and yeah its a user share Link to comment
JorgeB Posted July 3, 2019 Share Posted July 3, 2019 Is it faster if you transfer to/from the disk share (\\tower\cache)? Even with direct IO enable user shares have always some overhead, though I wound't expect that much. Link to comment
MomentarilyEpic Posted July 3, 2019 Author Share Posted July 3, 2019 yeah using a disk share it runs as its supposed to, 1gb/s write 700 (ish) mb/s read, is there a way i can get these speeds on user shares as i work with really big files (3d work) Link to comment
JorgeB Posted July 3, 2019 Share Posted July 3, 2019 Usually yes, I get speeds using user shares very close to disk shares with direct IO enable, don't know why such a big difference for you, but don't know what else you can try, likely related to your hardware or server config. Link to comment
MomentarilyEpic Posted July 3, 2019 Author Share Posted July 3, 2019 are there any settings you want me to take a screenshot of, to see if it will help also cpu: dual xeon x5650 motherboard: intel s5520hc Ram: 32gb ddr3 ecc My nvme is in an adapter at pcie gen2 X4 but should still saturate 10gb (as shown in disk share) also thanks for the disk share help, really appreciate it, now so close to actually setting up my dockers etc just gotta fix 10gbe cache for user shares Link to comment
JorgeB Posted July 3, 2019 Share Posted July 3, 2019 A faster CPU would definately help, likely a lot, SMB transfers are single threaded, in my testing I've found that for best performance with 10GbE a CPU with 2000+ single thread passmark rating is needed, yours only has 1228. Link to comment
MomentarilyEpic Posted July 3, 2019 Author Share Posted July 3, 2019 yeah that makes alot of sense, is there anything else i could try atm im a student and without buying an entirely new platform the max cpu single threaded score my motherboard can support is like 1500 (ish) with the x5690 thanks for all the help man Link to comment
JorgeB Posted July 3, 2019 Share Posted July 3, 2019 16 minutes ago, MomentarilyEpic said: is there anything else i could try Not that I can think of. Link to comment
bouis Posted July 3, 2019 Share Posted July 3, 2019 You can't multi-thread a single file transfer but you can transfer multiple files at the same time. Unfortunately I haven't found a good windows app to automate this but if you just do two copies at the same time it works because each copy gets its own samba thread. With SSDs there's very little performance decrease for doing two or even three sequential copies at once. If you find a windows app that automates this I'd love to hear about it. I tried a lot of them and had no luck. Link to comment
MomentarilyEpic Posted July 3, 2019 Author Share Posted July 3, 2019 yeah just tested with 2 transfers and yeah both at same speed (few drops everynow and then) but generally all good, guess i wont get full 10gb until i move out and can get a brand new server thats got better single threaded , my only real issue is the write backs from my nvme on unraid to nvme to my pc, its only peaking at 60mp/s 2 transfers make it 30 each and it wont go higher Link to comment
Vr2Io Posted July 3, 2019 Share Posted July 3, 2019 7 hours ago, MomentarilyEpic said: my only real issue is the write backs from my nvme on unraid to nvme to my pc, its only peaking at 60mp/s 2 transfers make it 30 each and it wont go higher The issue should be PC destination storage not fast enough. You may try create a big RAR non-compress file in NVMe and read test it in PC side to verify the issue. You won't got just 60MB/s. And UD got better performance then cache pool is normal. Link to comment
