September 16, 20215 yr Sorry to dig up an old thread - but in case this helps anyone else - I was also having this issue. When I try to save from the settings > CPU Pinning page, after clicking apply, getting sent to Settings, and clicking CPU Pinning again, I'd return and all of my settings were reset to whatever they were previously. However I checked in the individual docker with advanced view enabled, and sure enough, the isolated CPU pinning was being applied.
January 19, 20224 yr Remove any pinnings you may have manually made via editing the syslinux file, and the individual docker containers and then try again.
April 30, 20224 yr I haven’t made any manual pinnings in syslinux AFAIK, I can edit the pins manually through the advanced docker view. But it’s really tedious, I have over 30 containers I’m trying to manage. The CPU pinning page won’t save my selection, I’ve tried a number of things. I’m going to look more into the syslinux file but this seems like a bug. What’s the best way to report it, or is this fixable?
April 30, 20224 yr You'd have to post an applicable xml file where it's set in the template, but you're not able to save it through CPU pinning in Settings.
April 30, 20224 yr <?xml version="1.0"?> <Container version="2"> <Name>bazarr</Name> <Repository>lscr.io/linuxserver/bazarr</Repository> <Registry>https://github.com/orgs/linuxserver/packages/container/package/bazarr</Registry> <Network>internal</Network> <MyIP/> <Shell>bash</Shell> <Privileged>false</Privileged> <Support>https://github.com/linuxserver/docker-bazarr/issues/new/choose</Support> <Project>https://www.bazarr.media/</Project> <Overview>Bazarr(https://www.bazarr.media/) is a companion application to Sonarr and Radarr. It can manage and download subtitles based on your requirements. You define your preferences by TV show or movie and Bazarr takes care of everything for you.</Overview> <Category>Downloaders: Network:Other MediaApp:Video Tools:Utilities</Category> <WebUI>http://[IP]:[PORT:6767]</WebUI> <TemplateURL>https://raw.githubusercontent.com/linuxserver/templates/master/unraid/bazarr.xml</TemplateURL> <Icon>https://raw.githubusercontent.com/linuxserver/docker-templates/master/linuxserver.io/img/bazarr-logo.png</Icon> <ExtraParams/> <PostArgs/> <CPUset>22,23</CPUset> <DateInstalled>1651280372</DateInstalled> <DonateText/> <DonateLink/> <Description>Bazarr(https://www.bazarr.media/) is a companion application to Sonarr and Radarr. It can manage and download subtitles based on your requirements. You define your preferences by TV show or movie and Bazarr takes care of everything for you.</Description> <Networking> <Mode>internal</Mode> <Publish> <Port> <HostPort>6767</HostPort> <ContainerPort>6767</ContainerPort> <Protocol>tcp</Protocol> </Port> </Publish> </Networking> <Data> <Volume> <HostDir>/mnt/user/data/movies/</HostDir> <ContainerDir>/movies</ContainerDir> <Mode>rw</Mode> </Volume> <Volume> <HostDir>/mnt/user/data/tv/</HostDir> <ContainerDir>/tv</ContainerDir> <Mode>rw</Mode> </Volume> <Volume> <HostDir>/mnt/user/appdata/bazarr</HostDir> <ContainerDir>/config</ContainerDir> <Mode>rw</Mode> </Volume> </Data> <Environment> <Variable> <Value>99</Value> <Name>PUID</Name> <Mode>{3}</Mode> </Variable> <Variable> <Value>100</Value> <Name>PGID</Name> <Mode>{3}</Mode> </Variable> <Variable> <Value>022</Value> <Name>UMASK</Name> <Mode>{3}</Mode> </Variable> </Environment> <Labels/> <Config Name="WebUI" Target="6767" Default="6767" Mode="tcp" Description="Allows HTTP access to the internal webserver." Type="Port" Display="always" Required="true" Mask="false">6767</Config> <Config Name="Path: /movies" Target="/movies" Default="" Mode="rw" Description="Location of your movies" Type="Path" Display="always" Required="false" Mask="false">/mnt/user/data/movies/</Config> <Config Name="Path: /tv" Target="/tv" Default="" Mode="rw" Description="Location of your TV Shows" Type="Path" Display="always" Required="false" Mask="false">/mnt/user/data/tv/</Config> <Config Name="Appdata" Target="/config" Default="/mnt/user/appdata/bazarr" Mode="rw" Description="Bazarr data" Type="Path" Display="advanced" Required="true" Mask="false">/mnt/user/appdata/bazarr</Config> <Config Name="PUID" Target="PUID" Default="99" Mode="{3}" Description="Container Variable: PUID" Type="Variable" Display="advanced" Required="true" Mask="false">99</Config> <Config Name="PGID" Target="PGID" Default="100" Mode="{3}" Description="Container Variable: PGID" Type="Variable" Display="advanced" Required="true" Mask="false">100</Config> <Config Name="UMASK" Target="UMASK" Default="022" Mode="{3}" Description="Container Variable: UMASK" Type="Variable" Display="advanced" Required="false" Mask="false">022</Config> </Container> I tried several things with this one. I set it through the advanced view, but it wouldn't show as selected in the CPU pinning view. I then deselected it from the advanced view and tried to set it again in the CPU pinning view so I could see it with everything else. Nothing worked, I tried several different steps, but this is my current config for this one. Attaching a screenshot to show in the CPU Pinning view, nothing is selected. I read elsewhere this has to do with having containers that do not have associated xmls. But there's nothing I can do about that, I need some of these containers etc. But this just seems like a bug. It's ok if those containers without xml don't have CPU Pinning and other features, but I need them to run. Edited April 30, 20224 yr by gvkhna
July 2, 20251 yr This is an old post, but for anyone else stumbling on this and having the same issue, for me it was my custom docker container that had no option to set cpu pinning (container > edit > cpu pinning in advanced view). After removing the container I could pin from the settings page again.
