November 28, 20196 yr Power flickered and for some reason my ups did not hold. Anyway the disk3 shows disabled (red x). Wondering if I can get some assistance with a review. Disk 3WDC_WD30EFRX-68EUZN0_WD-WCC4N5LP0K5H - 3 TB (sdd) xfs_repair status -n Phase 1 - find and verify superblock... Phase 2 - using internal log - zero log... - scan filesystem freespace and inode maps... - found root inode chunk Phase 3 - for each AG... - scan (but don't clear) agi unlinked lists... - process known inodes and perform inode discovery... - agno = 0 - agno = 1 - agno = 2 - agno = 3 - process newly discovered inodes... Phase 4 - check for duplicate blocks... - setting up duplicate extent list... - check for inodes claiming duplicate blocks... - agno = 0 - agno = 2 - agno = 3 - agno = 1 No modify flag set, skipping phase 5 Phase 6 - check inode connectivity... - traversing filesystem ... - traversal finished ... - moving disconnected inodes to lost+found ... Phase 7 - verify link counts... No modify flag set, skipping filesystem flush and exiting. server-diagnostics-20191128-2328.zip Edited November 28, 20196 yr by rcmpayne
November 29, 20196 yr Community Expert On mobile now so can't look at Diagnostics, but filesystem repair isn't the fix for a disabled disk, that is for unmountable disks. The disabled disk is emulated and should be rebuilt. You should be able to even read the files on the emulated disk assuming it is mountable. Wait for someone to look at your Diagnostics and give you advice before trying anything else.
November 29, 20196 yr Community Expert 1 hour ago, johnnie.black said: Diags zip is not opening for me. Not me either - I assume the file is corrupt? From the size shown it does look smaller than I would expect.
