Jump to content
Eviltoon - Flash Problems
Eviltoon
  • Replies 53
As suspected you have issues with Flash. Are you booting from a USB2 port? (recommended)
Do you have a current backup of your flash drive?
Shutdown, put flash in your PC and let it checkdisk. While there make a backup of flash. If you ever need to you can always put the config folder from your flash backup on a new install and everything will be back.
For future reference, you can download a backup of flash from Main - Boot Device - Flash - Flash Backup. You should get a new backup anytime you make significant changes in the webUI. This is especially important if you make any changes to disk assignments.
Link to comment
my usb port  is a 3.0. The usb thumb drive is 2.0
the old usb was damaged and I need a new one
and I didn't bank it up. can it be fix without losing my  data
or am I going to have to buy a new copy and a new usb drive to and lose my data
Edited by Eviltoon
Link to comment
Do you have a USB2 port on your server?
Are you saying that the USB you booted from cannot be used now?
Do you know which disk was assigned to which slot?
I am going to have split this all into its own thread since it has absolutely nothing to do with Community Applications.
Link to comment
  • trurl unlocked this topic
not on the motherboard.
I had to get a new usb drive and now I have this problem.
yes I know what disk is assigned to the slot .
( I had to replace my usb drive it was damaged and I did not back it up. and had to get new software and install it. I put the disk back in exactly. and then I wet to get the plug ins and ran in to this problem. is there a way to fix this or do I need to buy a new copy with a new usb drive and restart my server all over and will lose all of my data
Link to comment
Are you sure? Often there will be a header on the motherboard that you can plug USB2 ports into.
Now that I recognized your other threads and that you already replaced your flash, I am still a little unclear. Is your new flash broken also? Is it completely unusable as a flash drive even if you reformat it?
Link to comment
  Only 75 emoji are allowed.
  • Create New...
