[Guide] Setting up Snipe-IT on Unraid
I just followed this guide last weekend to try everything out and got it working.  I was going to try pulling a backup from SnipeIT to restore on a more permanent instance in my production environment but get a wonderful error of:
 Error: Backup failed because The dump process failed with exitcode 2 : Misuse of shell builtins : mysqldump: Got error: 2005: Unknown MySQL server host '10.10.10.2:3306' (-2) when trying to connect . #0 /var/www/html/vendor/spatie/db-dumper/src/DbDumper.php(263): Spatie\DbDumper\Exceptions\DumpFailed::processDidNotEndSuccessfully() #1 /var/www/html/vendor/spatie/db-dumper/src/Databases/MySql.php(203): Spatie\DbDumper\DbDumper->checkIfDumpWasSuccessFul() #2 /var/www/html/vendor/spatie/laravel-backup/src/Tasks/Backup/BackupJob.php(252): Spatie\DbDumper\Databases\MySql->dumpToFile() #3 [internal function]: Spatie\Backup\Tasks\Backup\BackupJob->Spatie\Backup\Tasks\Backup\{closure}() #4 /var/www/html/vendor/laravel/framework/src/Illuminate/Support/Collection.php(638): array_map() #5 /var/www/html/vendor/spatie/laravel-backup/src/Tasks/Backup/BackupJob.php(255): Illuminate\Support\Collection->map() #6 /var/www/html/vendor/spatie/laravel-backup/src/Tasks/Backup/BackupJob.php(169): Spatie\Backup\Tasks\Backup\BackupJob->dumpDatabases() #7 /var/www/html/vendor/spatie/laravel-backup/src/Tasks/Backup/BackupJob.php(145): Spatie\Backup\Tasks\Backup\BackupJob->createBackupManifest() #8 /var/www/html/vendor/spatie/laravel-backup/src/Commands/BackupCommand.php(56): Spatie\Backup\Tasks\Backup\BackupJob->run() #9 /var/www/html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(36): Spatie\Backup\Commands\BackupCommand->handle() #10 /var/www/html/vendor/laravel/framework/src/Illuminate/Container/Util.php(37): Illuminate\Container\BoundMethod::Illuminate\Container\{closure}() #11 /var/www/html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(93): Illuminate\Container\Util::unwrapIfClosure() #12 /var/www/html/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php(37): Illuminate\Container\BoundMethod::callBoundMethod() #13 /var/www/html/vendor/laravel/framework/src/Illuminate/Container/Container.php(590): Illuminate\Container\BoundMethod::call() #14 /var/www/html/vendor/laravel/framework/src/Illuminate/Console/Command.php(134): Illuminate\Container\Container->call() #15 /var/www/html/vendor/symfony/console/Command/Command.php(255): Illuminate\Console\Command->execute() #16 /var/www/html/vendor/laravel/framework/src/Illuminate/Console/Command.php(121): Symfony\Component\Console\Command\Command->run() #17 /var/www/html/vendor/spatie/laravel-backup/src/Commands/BaseCommand.php(16): Illuminate\Console\Command->run() #18 /var/www/html/vendor/symfony/console/Application.php(1009): Spatie\Backup\Commands\BaseCommand->run() #19 /var/www/html/vendor/symfony/console/Application.php(273): Symfony\Component\Console\Application->doRunCommand() #20 /var/www/html/vendor/symfony/console/Application.php(149): Symfony\Component\Console\Application->doRun() #21 /var/www/html/vendor/laravel/framework/src/Illuminate/Console/Application.php(93): Symfony\Component\Console\Application->run() #22 /var/www/html/vendor/laravel/framework/src/Illuminate/Console/Application.php(185): Illuminate\Console\Application->run() #23 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(273): Illuminate\Console\Application->call() #24 /var/www/html/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php(261): Illuminate\Foundation\Console\Kernel->call() #25 /var/www/html/app/Http/Controllers/SettingsController.php(1085): Illuminate\Support\Facades\Facade::__callStatic() #26 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App\Http\Controllers\SettingsController->postBackups() #27 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction() #28 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(219): Illuminate\Routing\ControllerDispatcher->dispatch() #29 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Route.php(176): Illuminate\Routing\Route->runController() #30 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(681): Illuminate\Routing\Route->run() #31 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Routing\Router->Illuminate\Routing\{closure}() #32 /var/www/html/app/Http/Middleware/CheckPermissions.php(26): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #33 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\CheckPermissions->handle() #34 /var/www/html/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(43): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #35 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Auth\Middleware\Authenticate->handle() #36 /var/www/html/app/Http/Middleware/AssetCountForSidebar.php(56): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #37 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\AssetCountForSidebar->handle() #38 /var/www/html/vendor/laravel/passport/src/Http/Middleware/CreateFreshApiToken.php(50): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #39 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Laravel\Passport\Http\Middleware\CreateFreshApiToken->handle() #40 /var/www/html/app/Http/Middleware/CheckForTwoFactor.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #41 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\CheckForTwoFactor->handle() #42 /var/www/html/app/Http/Middleware/CheckLocale.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #43 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\CheckLocale->handle() #44 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(78): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #45 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle() #46 /var/www/html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #47 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle() #48 /var/www/html/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(67): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #49 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\EncryptCookies->handle() #50 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #51 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(683): Illuminate\Pipeline\Pipeline->then() #52 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(658): Illuminate\Routing\Router->runRouteWithinStack() #53 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(624): Illuminate\Routing\Router->runRoute() #54 /var/www/html/vendor/laravel/framework/src/Illuminate/Routing/Router.php(613): Illuminate\Routing\Router->dispatchToRoute() #55 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(170): Illuminate\Routing\Router->dispatch() #56 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}() #57 /var/www/html/vendor/barryvdh/laravel-debugbar/src/Middleware/InjectDebugbar.php(60): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #58 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Barryvdh\Debugbar\Middleware\InjectDebugbar->handle() #59 /var/www/html/vendor/fruitcake/laravel-cors/src/HandleCors.php(38): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #60 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Fruitcake\Cors\HandleCors->handle() #61 /var/www/html/app/Http/Middleware/PreventBackHistory.php(23): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #62 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\PreventBackHistory->handle() #63 /var/www/html/app/Http/Middleware/SecurityHeaders.php(26): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #64 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\SecurityHeaders->handle() #65 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #66 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle() #67 /var/www/html/app/Http/Middleware/CheckForDebug.php(25): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #68 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\CheckForDebug->handle() #69 /var/www/html/app/Http/Middleware/CheckForSetup.php(26): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #70 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\CheckForSetup->handle() #71 /var/www/html/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #72 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Fideloper\Proxy\TrustProxies->handle() #73 /var/www/html/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #74 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\View\Middleware\ShareErrorsFromSession->handle() #75 /var/www/html/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(56): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #76 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Session\Middleware\StartSession->handle() #77 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(63): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #78 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle() #79 /var/www/html/app/Http/Middleware/NoSessionStore.php(27): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #80 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\NoSessionStore->handle() #81 /var/www/html/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}() #82 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(145): Illuminate\Pipeline\Pipeline->then() #83 /var/www/html/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(110): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter() #84 /var/www/html/public/index.php(58): Illuminate\Foundation\Http\Kernel->handle() #85 {main} Backup failed because: The dump process failed with exitcode 2 : Misuse of shell builtins : mysqldump: Got error: 2005: Unknown MySQL server host '10.10.10.2:3306' (-2) when trying to connect .
The IP is internal of course so I'm not concerned with that being in the log.  Suggestions?
  • 2 months later...
I can't find a .env file when looking through the appdata on my server. Where is it hiding generally?
Hi, with the latest update, the barcode generator and Qr Code not work
  • 7 months later...
Hi thanks for the helpful posts, I've used it to try troubleshoot the "Whoops, looks like something went wrong." issue I am getting on Snipe-IT after logging in. This issue first occurred after relocating Snipe-IT to a new host. I have since generated a new APP Key successfully on the new host and can see the updated Key in the .env file. But I am still unable to sign in.
Is there any other advice you can offer to get this working?
Thank you
Thanks for the great tutorial.  Do you have plans to update the PHP version in your release? PHP 7.4 is currently EOL.
Thanks!
  • 3 months later...
On 9/7/2020 at 3:59 AM, Dimtar said:
Hi all.
I am trying to set this up but if I open the webui via the unRaid docker manager i get a page saying "Whoops, looks like something went wrong."
In the container log I see this:
Module ssl disabled.
To activate the new configuration, you need to run:
service apache2 restart
2020-09-07 11:58:27,028 CRIT Supervisor running as root (no user in config file)
2020-09-07 11:58:27,030 INFO supervisord started with pid 1
2020-09-07 11:58:28,031 INFO spawned: 'exit_on_any_fatal' with pid 20
2020-09-07 11:58:28,033 INFO spawned: 'apache' with pid 21
2020-09-07 11:58:28,034 INFO spawned: 'run_schedule' with pid 22
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 172.17.0.10. Set the 'ServerName' directive globally to suppress this message
No scheduled commands are ready to run.
2020-09-07 11:58:29,326 INFO success: exit_on_any_fatal entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-09-07 11:58:29,326 INFO success: apache entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2020-09-07 11:58:29,326 INFO success: run_schedule entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Haven't even reached the setup page yet.
EDIT: I hadn't done the app key right. Thats fixed now and I could proceed, just incase someone else has the same issue.
hey, how did you do that? I am facing the same problem.
Hello
I am not getting the setup page. Chrome tells me ERR_CONNECTION_REFUSED.
Here is the parts of config i changed:
Network Type: Custom br0 (ping works when container is running)
APP_URL: http://10.10.10.8:8080
MYSQL_PORT_3306_TCP_ADDR:
MYSQL_PORT_3306_TCP_PORT:
MYSQL_DATABASE: snipe-it
MYSQL_USER: *user_user*
MYSQL_PASSWORD: *password_password*
erverything else is unchanged
this is the Log outout:
grep: /config/nginx/site-confs/default.conf: No such file or directory
[migrations] started
[migrations] 01-nginx-site-confs-default: executing...
[migrations] 01-nginx-site-confs-default: succeeded
[migrations] 02-default-location: executing...
[migrations] 02-default-location: succeeded
[migrations] done
   Brought to you by linuxserver.io
To support the app dev(s) visit:
Snipe-IT: https://snipeitapp.com/donate
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID:    99
User GID:    100
Setting resolver to  127.0.0.11
Setting worker_processes to 8
generating self-signed keys in /config/keys, you can replace these with your own keys if required
Generating SnipeIT app key for first run
App Key set to base64:ntaI1ZXpSvqIxwb9BvH49Jb5vj+jgRZ5U9A+/PbyQOI= you can modify the file to update /config/SNIPE_IT_APP_KEY.txt
[custom-init] No custom files found, skipping...
[ls.io-init] done.
[migrations] 01-nginx-site-confs-default: skipped
[migrations] 02-default-location: skipped
[migrations] done
usermod: no changes
GID/UID
User UID:    99
User GID:    100
using keys found in /config/keys
[ls.io-init] done.
Can someone help me?
  • 4 months later...
Unable to get email working in the snipe-it docker.  Has anyone else got this working?
EmailSend Test Mail could not be sent.
Error: undefined
This will attempt to send a test mail to ${MAIL_ENV_FROM_ADDR}.
  • 7 months later...
I have lost css after an update. The site loads and logs in, but no styles or formatting making it unusable. It is using nginxproxymanager to load the certificate direct https://assets.mysite.com to the unraid ip and docker port.
Browser console errors:
Refused to load the stylesheet '<URL>' because it violates the following Content Security Policy directive: "style-src 'self' 'unsafe-inline'". Note that 'style-src-elem' was not explicitly set, so 'style-src' is used as a fallback.
Refused to load the script 'http://assets.mysite.com/js/html5shiv.js' because it violates the following Content Security Policy directive: "script-src 'self' 'unsafe-inline' 'unsafe-eval'". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
Failed to load resource: net::ERR_FAILED
Mixed Content: The page at 'https://assets.hampton.wa.edu.au/components' was loaded over a secure connection, but contains a form that targets an insecure endpoint 'http://assets.mysite.com//hardware/bytag'. This endpoint should be made available over a secure connection.
I have the same issue. I've tried updating it twice, but each time CSS is completely gone, and the SAML with Google doesn't work anymore either.
I haven't received an update from the devs, but I will add the info you provided, Hamptonict!
I have found a fix!
Add the enviroment variable:
APP_FORCE_TLS=true
Source: https://github.com/snipe/snipe-it/issues/14892
Also, if SAML isn't working for anyone, you have to add the following line to Custom SAML settings in the Snipe-IT webUI:
baseurl=https://assets.yourwebsite.com/saml/
Source: https://github.com/snipe/snipe-it/issues/14895
