muslimsteel Posted July 10, 2022 Share Posted July 10, 2022 Hello, I have had kernel panics recently about once or twice a week. Googling suggests it could be memory issue (even though I am running ECC RAM) or could be some other issue with docker networking (but nothing has changed there). So I just wanted to post my logs to get a second opinion before doing more troubleshooting. Attached are two diagnostics pulled after the reboot, and the most recent syslog. I don't think the syslog was captured for the first kernel panic, but the most recent one on 7/9/2022 @16:06 local time should be there. Thanks in advance for the help with this! All_2022-7-10-9_8_40.csv hulk-diagnostics-20220710-0917.zip hulk-diagnostics-20220706-0852.zip Quote Link to comment
Solution JorgeB Posted July 11, 2022 Solution Share Posted July 11, 2022 See if this applies to you, if yes, upgrading to v6.10 and switching to ipvlan should fix it (Settings -> Docker Settings -> Docker custom network type -> ipvlan (advanced view must be enable, top right)), or see below for more info.: https://forums.unraid.net/topic/70529-650-call-traces-when-assigning-ip-address-to-docker-containers/ See also here: https://forums.unraid.net/bug-reports/stable-releases/690691-kernel-panic-due-to-netfilter-nf_nat_setup_info-docker-static-ip-macvlan-r1356/ Quote Link to comment
muslimsteel Posted July 11, 2022 Author Share Posted July 11, 2022 Yea I did see that, thought it was odd that it has been running pretty stable for a while now and this suddenly popped up. Will check them out more thoroughly and let you know. Thanks. Quote Link to comment
muslimsteel Posted July 18, 2022 Author Share Posted July 18, 2022 Just as an FYI, I upgraded to 6.10.3 and then changed the Docker network setting to ipvlan and the server has been stable for over 5 days now. Will continue to monitor, thanks! 2 Quote Link to comment
