【Unassigned Devices Problem】Can't MOUNT remote folder
Plugin: Unassigned Devices (UD)
Two UNRAIDs
I need to get one of my UNRAIDs to mount the other UNRAID
I have confirmed that the other UNRAID is working (my Windows and Linux are both working)
Problem: "After adding a new UNRAID, it can only be used once, and cannot be used after rebooting".
You have to delete it before it works again!!!
Debug image attached
1. Can press the orange MOUNT button, but I can't mount it normally.
2. System SAMBA log
3.unassigned.devices log
Do the following:
  • Set "Debug Log Level:" in UD Settings to "None".
  • Update all your plugins.
  • Reboot.
  • Try to mount the remote share once more.
  • Post diagnostics.
There are so many debug messages in the log I can't find anything.
18 hours ago, dlandon said:
Do the following:
  • Reboot.
  • Post diagnostics.
diagnostics-20221103-0033.zip
For future reference, you can go directly to the correct support thread for any of your plugins by clicking its Support Thread link on the Plugins page of your Unraid webUI.
You are getting a credentials failure on the //192.168.10.11/isos share.  Don't use any special characters in your credentials.
I use  Number+letters password (Length 12) to connect.
But ,still the same...
Edited by wdnaser
Check the credentials to be sure they are right.
