Maticks Posted May 20, 2023 Share Posted May 20, 2023 (edited) My disk 7 died so i RMA'd the disk and put in a replacement drive. it started Rebuilding and my disk 8 started throwing some UDMA Errors and it was going up in the hundreds so i shutdown my system. Replace my SATA cabling for Disk 9 when i booted it up i was shocked to see disk 9 is now disabled but i can see the temp on the disk. Starting the array i see this I am confused it is rebuilding but it isn't rebuilting. Not sure how to get disk 9 back online? How do I fix this mess? Edited May 20, 2023 by Maticks Quote Link to comment
Maticks Posted May 20, 2023 Author Share Posted May 20, 2023 tower-diagnostics-20230521-0733.zip Quote Link to comment
Maticks Posted May 20, 2023 Author Share Posted May 20, 2023 i managed to get Disk 9 back operational and marked the Parity as being correct but i can't seem to kick off disk7 rebuilding. its doing something not sure what it is doing though doesn't say. My data on Disk 9 looks good now just need to somehow bring disk 7 back to life. Quote Link to comment
JorgeB Posted May 21, 2023 Share Posted May 21, 2023 You did a new config and because of that lost he option to rebuild disk7, I assume you checked parity is already valid? If yes and there were no writes to the array it may still be possible to force it to rebuild disk7. Quote Link to comment
