July 5, 20242 yr Community Expert Try the other backup but most likely will be the same: btrfs-select-super -s 2 /dev/md1p1 btrfs-select-super -s 2 /dev/md3p1
July 5, 20242 yr Community Expert 37 minutes ago, fusselnerd said: Can you recommend a read about btrfs and Unraid array? I'm missing the fundamentals, obviously, so I'd like to dig into it a bit. Not sure if it would be easy to find specif btrfs info for the array, but if you search for btrfs in general there are lots of resources on the net, Unraid uses regular btrfs.
July 5, 20242 yr Author Yeah, it's the same result: root@GrayBigBerta:~# btrfs-select-super -s 2 /dev/md1p1 ERROR: superblock checksum mismatch ERROR: superblock checksum mismatch No valid Btrfs found on /dev/md1p1 ERROR: open ctree failed root@GrayBigBerta:~# btrfs-select-super -s 2 /dev/md3p1 ERROR: superblock checksum mismatch ERROR: superblock checksum mismatch No valid Btrfs found on /dev/md3p1 ERROR: open ctree failed
July 5, 20242 yr Author Just now, JorgeB said: Not sure if it would be easy to find specif btrfs info for the array, but if you search for btrfs in general there are lots of resources on the net, Unraid uses regular btrfs. Thank you! 🙏
July 5, 20242 yr Community Expert 6 minutes ago, fusselnerd said: No valid Btrfs found on /dev/md1p1 ERROR: open ctree failed I'm afraid the backup superblocks are also damaged, best option now would be to use something like UFS explorer to scan the disks and see if it can recover the data, the free trial should allow you to see if that's possible, before having to pay for for it.
August 8, 20242 yr Author Hi @JorgeB Hi finally had time to do the recovery: with UFS I managed to restore almost all data and backed it up. Thank you very much for that tip. What will be the next step?
August 8, 20242 yr Community Expert Post a screenshot of main to refresh my memory as to the current array status.
August 8, 20242 yr Community Expert And both the emulated disks 1 and 3 are not mounting correct? Same for the actual disks using UD?
August 8, 20242 yr Author Correct. If I mount them or start the array with emulated disks I get the error "Unmountable... missing file system" or so. In syslog it's shown that the BTRFS filesystem ist corruped (ERROR: superblock checksum mismatch). We tried to restore the superblock but it was not possible because I started the rebuild by mistake. Now, I restored the actual data by hand (UFS). I didn't assign the disks or started the array since then. PS: You also mentioned in a previous post that I should scrub the other disks and reset the errors.
August 8, 20242 yr Community Expert If you have already recovered the data, you can do a new config to assign the disabled disks, then start the array to re-sync parity, you can then format the disks and restore the data.
August 8, 20242 yr Author Allright, I did a new config with all disks assigned the same as before except the two disabled disks. Parity is syncing now. Then I'll format the two disks, assign them and recover the backed up data. This might take a couple of days. I'll get back to you when it's finished for the last steps (I guess), scrubbing and error-reset. Thank you so far.
August 8, 20242 yr Community Expert 1 hour ago, fusselnerd said: except the two disabled disks. Parity is syncing now. Then I'll format the two disks, assign them This is the wrong order to do things. If you did New Config without the disks, then they are not part of parity. If you assign the disks after parity builds, Unraid will have to clear them so parity remains valid. After the disks have been assigned and cleared, then you can format them.
August 8, 20242 yr Community Expert 1 hour ago, fusselnerd said: This might take a couple of days. I'll get back to you when it's finished @fusselnerd See my post above
August 8, 20242 yr Author Hi @trurl Oh I see, thank you for correcting me! I stopped the sync and did a New Config, again, and assigned the two disks. I would now start the array to start the parity-sync. Is this the correct order?
August 8, 20242 yr Community Expert 1 minute ago, fusselnerd said: Is this the correct order? yes. You can format them after parity builds, or even while parity builds, and the format (filesystem creation) will be part of parity just like any other write to the array. Be sure to notice the list of disks that will be formatted. DO NOT enable and click FORMAT if any other disks are listed.
August 8, 20242 yr Author Thanks a lot! I started the sync and formated both disks. Also, no other disks were listed.
August 8, 20242 yr Community Expert That screenshot is clipped on the right, so doesn't include enough information to reassure me about your disk contents (USED FREE).
August 13, 20242 yr Author Hi, Sync and data restore finally finished without errors. Also no errors in syslog and drive logs. Respective shares are shown as protected.
August 14, 20242 yr Author As you suggested here On 7/4/2024 at 12:49 PM, JorgeB said: You will also need to scrub all the disks that have corruption detected, then reset the errors and monitor to see if new ones come up, but this is for later. I checked the other disks for errors with btrfs dev stats /mnt/<disk> and it turned out that all disks have errors: root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk2 [/dev/md2p1].write_io_errs 0 [/dev/md2p1].read_io_errs 0 [/dev/md2p1].flush_io_errs 0 [/dev/md2p1].corruption_errs 22 [/dev/md2p1].generation_errs 0 root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk4 [/dev/md4p1].write_io_errs 359 [/dev/md4p1].read_io_errs 1 [/dev/md4p1].flush_io_errs 0 [/dev/md4p1].corruption_errs 71 [/dev/md4p1].generation_errs 0 root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk5 [/dev/md5p1].write_io_errs 0 [/dev/md5p1].read_io_errs 0 [/dev/md5p1].flush_io_errs 0 [/dev/md5p1].corruption_errs 287 [/dev/md5p1].generation_errs 0 root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk6 [/dev/md6p1].write_io_errs 0 [/dev/md6p1].read_io_errs 0 [/dev/md6p1].flush_io_errs 0 [/dev/md6p1].corruption_errs 12 [/dev/md6p1].generation_errs 0 except the recovered disks: root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk1 [/dev/md1p1].write_io_errs 0 [/dev/md1p1].read_io_errs 0 [/dev/md1p1].flush_io_errs 0 [/dev/md1p1].corruption_errs 0 [/dev/md1p1].generation_errs 0 root@GrayBigBerta:/mnt# btrfs dev stats /mnt/disk3 [/dev/md3p1].write_io_errs 0 [/dev/md3p1].read_io_errs 0 [/dev/md3p1].flush_io_errs 0 [/dev/md3p1].corruption_errs 0 [/dev/md3p1].generation_errs 0 Questions: I intend to run scrub in a small script to scrub all disks after one after another. What parameters should I use? Will this do (for each disk)? btrfs scrub start -B /dev/disk# As I understand array disks have single disk file systems. Therefore automatic repair should not be possible, right? Should I use the -r option?
August 14, 20242 yr Community Expert 51 minutes ago, fusselnerd said: As I understand array disks have single disk file systems. Therefore automatic repair should not be possible, right? It can still be possible for metadata, but not for data, but always run a correcting scrub anyway, since the other one doesn't have much point. 52 minutes ago, fusselnerd said: btrfs scrub start -B /dev/disk# That should work, but you can also use the built in scheduler.
August 16, 20241 yr Author Scrub of all disks resultet in four currupted files. I deleted the files and resetted the btrfs scrub stats, then run scrub again: 0 errors. Is there anything else I should check/do before bringing the server online?
August 16, 20241 yr Community Expert Should be OK, then just make sure to monitor/scrub for any new errors in a month or so.
